Viewing 15 posts - 4,441 through 4,455 (of 6,299 total)
  • in reply to: Problem when installing #4839
    You should remove Rapid SCADA using the ScadaSetup.exe
    Make sure that C:\SCADA doesn’t extist after uninstall.
    Install Rapid SCADA again.
    in reply to: Mobile client and Rapid SCADA #4835
    I’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
    Is manjey73 said, VPN is the most preferable and safe way.
    Also you can use dynamic DNS service, such as https://www.noip.com/ In this case, you need to register the service, enter the credentials into your router, setup NAT on the router, and then connect like youraddress.ddns.net/scada
    OK, I added the author to email thread. Hope he will answer.
    in reply to: Error data fire system #4833
    Hola
    00 00 00 00 00 06 F6 03 00 00 00 05
    F6 is a unit ID, in terms of Rapid SCADA this is a device address defined in Administrator.
    While another software uses Unit ID = 1.
    You can check it by http://modbus.rapidscada.net/
    First of all, change the device address to 1.
    in reply to: Modbus TCP over GPRS (S27x GPRS RTU) #4816
    I suppose, you should provide links to screenshots of your settings and copy communication log here.
    in reply to: 5.6.0 Web is not normal #4814
    I can connect to your PC remotely and fix the issue. This is a commerical service. To get it, please contact us by email.
    in reply to: Formulas Math Functions #4813
    How can I do this?
    For example, Cnl * 10
    is it possible to implement a digital momentary start/stop?
    Please clarify the question.
    in reply to: How to install rapidscada in Windows xp OS? #4812
    Rapid SCADA requires .NET Framework 4.6 or higher. You need at least Windows 7. See this
    in reply to: 5.6.0 Web is not normal #4808
    There was no changes in the project format. To get more error details, press F12 in a browser and watch the Console tab.
    in reply to: How to install rapidscada in Windows xp OS? #4807
    I’m afraid that Windows XP is too old. You can’t install .NET Framework 4.6 on XP that is required for Rapid SCADA.
    in reply to: 5.6.0 Web is not normal #4804
    After the update,paste the old project.
    Did the problem appears only when you apply the old project? Does it work after clear installation?
    in reply to: Ubuntu Installation Forbidden from Apache2 #4803
    Thanks for the solution ))
    Also the web site referenced in the install_with_apache.txt file does not resolve
    That’s true. That’s why there is a ready file scada.conf in the distributive package.
    in reply to: Function 05, Force single coil #4797
    Check Commands enabled checkbox of a communication line. If it doesn’t help, copy communication line log here in a moment of sending command.
    in reply to: Change Led colour #4794
    Can I do it for 2 conditions?
    Yes.
    a ? b ? c : d : e
    I forget how the above works ))
    in reply to: DotNet Framework issue #4793
    In 2019 we may move to .NET 4.7, so you probably should think about upgrading the server OS.
    .NET 4.7 is required to use the same .NET Standard DLLs with cross-platform .NET Core build of Rapid SCADA.
