Formulas Math Functions
Forum Home Forums Understanding the Software Formulas Formulas Math Functions
  • #4134
    ahmt_87
    Dear Sir;
    I am reading values from modbus devices, kwh.I want to calculate the difference on channel 65 every 8 hours.How can i do this.Could you show me a simple calculation example.
    Channel 65 adjusted for the kwh.I am able to read values.But i need some calculations on it.
    Let’s say;
    14.08.2018 at 08:00 Chnanell 65 is 1000 kwh
    14.08.2018 at 16:00 Channel 65 is 2000 kwh
    i want to calculate this difference.
    Thank you very much
    #4135
    This calculation is difficult to implement using built in formulas because they work with current values. I suggest Elastic Report plugin, please check the demo which performs what you need.
    #4136
    The example shows daily difference. Elastic Report also supports hourly difference. In case of 8 hours difference, we can discuss implementing this feature.
    #4810
    btrindade
    Hi there,
    I’m new to using this software.
    I need to collect a live analogue value and multiply or divide it by a constant value. How can I do this?
    Also, is it possible to implement a digital momentary start/stop?
    #4813
    How can I do this?
    For example, Cnl * 10
    Please clarify the question.
