Function 05, Force single coil
Forum Home › Forums › Communicating with Devices › Modbus › Function 05, Force single coil
  • #4796
    CR
    Sirs,
    First of all thanks for this open source SCADA, it’s amazing !
    I’m using an acquisition box and by means of a simulator I’m able to set and reset de first coil using the following commands:
    Set coil:
    02 05 00 00 FF 00 8C 09
    Reset Coil:
    02 05 00 00 00 00 CD F9
    I’ve confuigured the template to read 16 discrete inputs (Func. 02) and Coil status (Func. 01) but I cannot get working the command for Func. 05. Here is how I configured the template in term of a command:
    Command Parameters
    Coils (0X)
    Function Code:05
    Element address: 0
    Command number: 1
    Addressing:
    Zero-base (ticked)
    Decimal (ticked)
    I’ve tried to execute the command (password: 12345) without any succes. I do not even see the command in the log. Can you please indicate me what I’m doing wrong. Again, thanks a lot for your help and patience.
    CR
    #4797
    Check Commands enabled checkbox of a communication line. If it doesn’t help, copy communication line log here in a moment of sending command.
    #4798
    CR
    Mikhail,
    Thanks a lot for your support. It worked !
    Best regards.
    CR
