Viewing 15 posts - 406 through 420 (of 6,287 total)
  • Mikhail
    In Rapid SCADA it’s a bit different:
    When you click a button, a popup dialog is shown, where you can choose an option.
    To do that, you need to configure a channel of the output type. Then specify the channel number in the button properties.
    in reply to: Logging fast I/O #16899
    Please don’t mess up many topics in one. Create new topic for other questions.
    Archive kind should be set to historical.
    in reply to: Logging fast I/O #16880
    Manually add a row in the Archives table.
    If you provide screenshots, I can check.
    in reply to: Execute weblink in channel table #16876
    That’s interesting!
    in reply to: Logging fast I/O #16873
    You can write data on change. It is supported by PostgreSQL archives.
    > Just for a selected channel, not all of them.
    It’s needed to create a new archive in the configuration database and in the Server settings. The created archive should not be marked as default. Then you can set an archive mask of the channel to write that channel to the certain archive.
    Ask for the details if needed.
    in reply to: Execute weblink in channel table #16856
    In the Scripts table add
    public double StartProcess()
      Process.Start(@"/opt/scada/myscript.ssh");
      return 1.0;
    and create myscript.ssh containing the necessary commands.
    Then use that function in the output formula.
    in reply to: UTC date and time #16855
    The time seems to be converted from UTC to local time, so in order to become UTC in the view, I would have to convert it additionally.
    That’s right. Probably, we need to add an additional option to control displaying.
    in reply to: Execute weblink in channel table #16849
    To shut down a Linux machine it’s better to connect by SSH and execute a shell command.
    in reply to: Execute weblink in channel table #16848
    You can create a channel with an output formula that executes an external script to shutdown the machine.
    But it’s not a good practice.
    in reply to: scheme views showing blank #16846
    Open the folder SCADA\ScadaWeb\wwwroot\plugins\Scheme\js in the file explorer and check if those files exist.
    If they don’t exist, copy the files from the installation package.
    • This reply was modified 10 months, 1 week ago by Mikhail.
    in reply to: scheme views showing blank #16839
    Could you provide a screenshot of the error? I need a path of the missed file.
    > and scheme’s display on another computer
    Do you mean that it works when a client opens a scheme remotely hosted on the same server? Or another installation?
    in reply to: DB Import string #16838
    Currently long strings are not supported by the DrvDbImport drvier. I hope, we will implement it in the future.
    If the strings have fixed values, they can be presented as numbers, and enumerations can be used.
    Alternatively, use the community driver noticed above.
    in reply to: Execute weblink in channel table #16837
    Scripts are executed on server side, so they have no connection with a web browser.
    How is the information expected to be presented to the end user?
    in reply to: Logs #16836
    If I set this to “Channel Status Has Changed”, some event would possible get logged when the Status changes to 1 which I can later review.
    Try “Channel Data Has Changed” or “Channel Status Has Changed”. Play with it.
    in reply to: scheme views showing blank #16824
    Press F12 to open browser tools. In the Console tab there are additional info about scheme loading.
