scheme views showing blank
Forum Home › Forums › Runtime Bugs › scheme views showing blank
  • #16819
    WayneS
    All of my scheme view files (.sch) are showing blank – they look OK in the adminsitrator, but the screen is totally blank. The logs don’t show any issues and the table views all work well – any suggestions? I have tried naking new scheme views with only static text but they still show as blank?
    #16820
    WayneS
    I also tried making a new project with just a simple screen with one piece of static text – it also shows up as blank.
    #16824
    Press F12 to open browser tools. In the Console tab there are additional info about scheme loading.
    #16831
    WayneS
    Thanks, the problem seems to be that the scheme-render.js is failing – error message says:Failed to load resource: the server responded with a status of 404 (not found).
    I have reloaded rapid scada (version 6.2.1.3) but that didn’t help. The project runs OK (and scheme’s display on another computer) so I’m a little perplexed.
    #16839
    Could you provide a screenshot of the error? I need a path of the missed file.
    Do you mean that it works when a client opens a scheme remotely hosted on the same server? Or another installation?
    #16842
    WayneS
    Hi Mikhail,
    screenshot
    The project runs OK on another server (backup). If you access the app from the main server, the scheme views don’t work. If I run the project on another server the scheme views do work, so seems to be something with setup on main computer. I have removed rapid scada and reinstalled, but no difference.
    #16846
    Open the folder SCADA\ScadaWeb\wwwroot\plugins\Scheme\js in the file explorer and check if those files exist.
    If they don’t exist, copy the files from the installation package.
    • This reply was modified 1 year, 3 months ago by Mikhail.
