Viewing 15 posts - 2,086 through 2,100 (of 6,288 total)
  • in reply to: V6 Status Severity #11888
    Severity, specified for a channel status, will be set for generated events if a channel has that status.
    For now, the web interface uses only main color. The second and back color columns are made for future use.
    in reply to: Web Page View #11882
    The example is for v5. It does not work with v6.
    Use the appropriate web page for v6.
    Open browser tool by pressing F12 and check the actual page URL.
    in reply to: V6 Add device and Add channel under *.tbl #11881
    If there is a question, please clarify it.
    in reply to: V6 Numeric address and String address #11880
    Numeric address = device address (eg Modbus device address using 2 or 3 or ..)
    String address = Call number (IP address to be connected for the device eg 192.168.17.21 or others)
    Yes. You can enter 127.0.0.1 into String Address.
    in reply to: v6 notification plug in #11879
    Notification Plugin for v6 is not developed yet.
    in reply to: V6 Bit mask and Archive mask #11878
    Archive mask specifies what archives store channel data. If empty, the default archives are used.
    in reply to: Version 6 related #11877
    Tag number is the synonym of the Signal field in the 5th version.
    Tag code is similar to tag number, but it can contain any string.
    Data type of the channel determines how channel data are stored. The empty cell means Double.
    in reply to: SMS GSM Cinterion Modem #11876
    When you send a custom command, the driver sends data that is specified for the command.
    in reply to: Rapid SCADA 6 Beta #11853
    There is a DB Export module that can write data to MSSQL.
    We don’t have a plan to develop MSSQL archive (similar to ModArcPostgreSql, for example). It can be done by other developers, or we can implement MSSQL archive by a contract.
    in reply to: SMS GSM Cinterion Modem #11852
    Dear Han,
    Rapid SCADA includes a driver KpSms.dll that supports AT command set for sending SMS. To answer if a certain module works with the driver or not, you should test them together.
    in reply to: v6, mqttnet upgraded from 3.1.2 to 4.1.4.563 #11849
    Thank you. The drivers will be included in the next release.
    in reply to: V6 Video Support #11848
    Can the team help to prepare the video support if we can learn to use the new version V6 in a faster way?
    I suggest creating a demo project to learn the v6 faster. If something is not clear, ask on the forum.
    in reply to: Webstation webpage #11847
    in reply to: Version 6 issues #11846
    May I know where is the configuration and plug in the Webstation now?
    Webstation is configured using the Administrator application.
    Documentation will be added after porting the modules.
    in reply to: Web Page View #11840
    What version of Rapid SCADA do you use, 5 or 6?
    I tried with the example and don’t work
    Could you provide screenshots that contain actual results?
