Viewing 15 posts - 2,026 through 2,040 (of 6,288 total)
  • in reply to: Disable Automatic Control Module v5 #12018
    To cancel a command, an output channel formula should return double.NaN or null, depending on the required conditions.
    Button component can be bound to an input channel that allows to hide or disable a button. But the same command can be sent from another table view, for example.
    in reply to: Map: Links #12012
    What’s the difference between plugins’ Personal and Business license?
    The answer is here.
    in reply to: Migrate data from 5.x to 6.X #12011
    Hi!
    Please check this topic. In case of questions, ask there.
    in reply to: config fie upload #12007
    in reply to: Map: Links #12006
    May be you need a kiosk mode of the browser.
    in reply to: Map: Links #12005
    Such behavior depends on a browser. In Chrome, if you start full screen mode by pressing F11, it does not exit on page navigation.
    in reply to: config fie upload #12002
    Open Config/ScadaInstanceConfig.xml for editing. Set ActiveStorage to PostgreSqlStorage, and restart Rapid SCADA services.
    in reply to: SMS GSM Cinterion Modem #12000
    According to the log, the modem does not respond: Receive: no data
    You could compare with the previous logs.
    Check connection settings.
    • This reply was modified 3 years, 4 months ago by Mikhail.
    in reply to: V6 – Extra Scheme Components #11996
    in reply to: config fie upload #11993
    Weird. What is written in Agent settings and log?
    in reply to: V6 – Extra Scheme Components #11992
    Thank you for finding this bug.
    Please download and update the plugin again. Now it should work in Scheme Editor also.
    Note: plugin registration is not needed for editing schemes.
    in reply to: Elastic report V6 download link #11985
    It’s possible. Click Main Menu – Reports -…
    in reply to: config fie upload #11983
    If you delete the existing configuration files, is possible to upload new configuration?
    in reply to: V6 – Extra Scheme Components #11982
    You should update Rapid SCADA to version 6.0.1 to use the components.
    in reply to: Elastic report V6 download link #11979
    Elastic Report has not been ported to v6 yet. Work status is here.
