June 7, 2023 at 10:44 am in reply to: Retrieve the channels and devices list from Scada Scheme Editor V5 #12772
Currently, Scheme Editor is taken from Rapid SCADA 5. So it’s difficult to integrate it with a project of Rapid SCADA 6.
Do you need to display channels that exist in the project inside Scheme Editor?
You need a channel of the Output type. Command code must match with the module. If you provide screenshots of the settings and sending command, I could check.
You can run *.bat or *.sh from formulas. For example:
Process.Start(@"C:\1.bat");
MikhailModeratorAlso possible
dateTime = DateTimeOffset.FromUnixTimeSeconds((long)unixTimeStamp).ToUniversalTime();
Thank you for the update.
Note that DrvOpcUa.View.xml affects user interface. DrvOpcUa.Logic.xml affects how the driver works.
But when I set command as Send Command instead of Send Command Now, it does its job.
Could you compare the messages in ScadaServer.log in the both cases and provide screenshots?
First of all, I would log some message if
data.type == "report"to check whether that section is executed.
When a window is opened in a new tab, a browser decides whether to use a tab or separate window. You should check browser settings.
When a window is opened in a popup, it is specified by SCADA. To change it, you can edit JavaScript files, however, it’s not recommended.
MikhailModeratorYou can send a string command like
cmd=ExportArchive startDT=2022-12-23 10:00:00 endDT=2022-12-23 11:00:00to export historical data.
When DB Export module receives such command, it executes the historical data queries that exist in the module configuration.
In such situation, using JS is the right method. If it doesn’t work, provide more info.
If you simply need to change command value, you can set a formula of the output channel to1, for example.Do you have an input channel that changes according to a command?
ModRapidGate.xml and ModRapidGate_Reg.xml are created automatically in the proper location of the project when you configure the module using the Administrator application.
MikhailModeratorI guess, OPC server should have an option that allows to restrict publishing speed. Or may be, it’s a client subscription includes such parameter. For example, Rapid SCADA OPC UA client subscription have the Publishing interval option.
