Viewing 15 posts - 1,141 through 1,155 (of 6,266 total)
  • in reply to: ModDbExport #14387
    The feature to export data on timer is available in Rapid SCADA 6.
    Using 5.8.4, you can try the above method, but it seems too tricky.
    in reply to: Error while trying to add an OPC Classic device #14382
    Did you manage to connect?
    in reply to: jQuery issues in #14375
    The popupLocator object is declared in popup.js, which is referenced by the web pages.
    in reply to: Array variables through opcua #14374
    If an OPC UA server provides motor states as an array, you can read them as an array and store in a single channel having length 10. But in the scheme view, you need to address channels by their numbers. Provide screenshots of the settings for more details.
    in reply to: Error while trying to add an OPC Classic device #14373
    You can use this simple utility for testing. Also try 3rd party OPC clients, such as Matrikon OPC explorer and Prosys.
    in reply to: jQuery issues in #14358
    I cannot find the above lines in scheme-render.js
    The above is a good example of what I was saying.
    Also you can try to set an archive option to write data on each change. But it may require a lot of disk space if data change too fast.
    in reply to: Array variables through opcua #14355
    Could you provide an example?
    in reply to: Modbus Data Formula #14354
    How do I make the LED indicator condition show green when no alarm, and red when alarm is on
    Open the Conditions property of the component and change the colors.
    in reply to: Create Array template elements #14353
    For example, the device returns a list of registers A1…A10. And a manufacturer says that this is an array. A driver should create a tag that has length > 1 to support an array. But the current Modbus driver does not support this.
    While OPC devices can return data of array types. And the OPC driver also supports this.
    in reply to: Array variables through opcua #14342
    OPC UA driver in Rapid SCADA 6 can read arrays from the OPC server. On SCADA level each array element is stored in a separate channel. It’s easier to try and watch how it works.
    Yes, event has it’s own timestamp that equals to an event creation time. While archive timestamp may be different if the archive uses a writing period. But 20 seconds difference is too big if the archive period parameter is 1 second. I would be OK if the archive writing period is 1 minute for example.
    in reply to: Function in the output channel in v5 other than v6 #14339
    If I understand you correctly, the channel 5767 (Output) was created to set the value of the channel 5567 (Calculated).
    Try disabling the channel’s 5567 formula. Commands should work in this case. Next, you need to fix CKLP. Could you describe how CKLP should work?
    in reply to: Convert historical data from V5 to V6 #14337
    Thank you for the update. Please tell about the results.
    in reply to: Error while trying to add an OPC Classic device #14336
    May be you need to install OPC Core Components (available on our website).
    Also, you should configure access rights in DCOM settings, which can work unpredictable.
    OPC DA does not need to specify TCP port.
    Consider installing the Communicator service on the same machine as OPC server. Communicator can send data to SCADA-Server remotely. And configuration may be simplified.
