ModDbExport
  • #14383
    Matt3
    Dear Mikhail
    I have an application working in version 5.8.4.
    I want to now export channel data 100-118 to a number of tables in an MS Server database.
    At the moment when I add a “Current data trigger”, the values are written at 1 to 2 seconds intervals continuously.
    I want to export data to table1m at 1 minute, to table5m at 5 minutes and to table1h at 1 hour intervals. How can I export at these time intervals?
    Kind regards
    Matt
    #14386
    JurasskPark
    If you have good knowledge of SQL writing queries, you can make a temporary table where you will add the current values. the trigger in this temporary table will sort the values into the required tables.
    I wrote my own module and SQL scripts for this.
    #14387
    The feature to export data on timer is available in Rapid SCADA 6.
    Using 5.8.4, you can try the above method, but it seems too tricky.
    #14389
    Matt3
    Thank you. I will take a look at both suggestions.
