Function in the output channel in v5 other than v6
Forum Home › Forums › Development and Integration › Function in the output channel in v5 other than v6
  • #14334
    enviromixti
    We are in the process of migrating to a new machine and a new version of Rapid SCADA from version 5.5.2.1 to 6.1.1.0. The old version was copied to a new version but it does not have the same names
    In version 5.5.2.1 and script that was created with the name CKLP
    https://ibb.co/ZLQdp51 Input Channels v5
    double CKLP(double val) {
         DateTime nowDT = DateTime.Now;
        if(val==1){
            return (Cnl);
       else {
            if ((nowDT.Hour == 00) && (nowDT.Minute == 1)) {
                return (0);
           } else {
                return (Cnl);
    In version 5.5.2.1 there is the Command Type: Standard
    http://ibb.co/r4R45Rp Output channels v5
    Web
    http://ibb.co/V93cyfh Web
    In version 6.1.1.0 the same v5 script with public inclusion
    https://ibb.co/NtvwqYk Input v6
    public double CKLP(double val) {
        if(val==1){
            return (Cnl);
       else {
                return (0);
           } else {
                return (Cnl);
    In version 6.1.1.0 there is no Command Type: Standard
    https://ibb.co/qxkFxJs output channels v6
    what should I do now?
    • This topic was modified 2 years, 6 months ago by Mikhail.
    #14335
    enviromixti
    output
    input
    v502
    Bot-o1
    Bot-o
    capri-5
    #14339
    If I understand you correctly, the channel 5767 (Output) was created to set the value of the channel 5567 (Calculated).
    Try disabling the channel’s 5567 formula. Commands should work in this case. Next, you need to fix CKLP. Could you describe how CKLP should work?
