Array variables through opcua
Forum Home › Forums › Communicating with Devices › OPC › Array variables through opcua
  • #14341
    BrainBranchetti99
    I would be looking for the possibility of accessing via opc ua in a 1500 cpu.
    Is there the possibility of accessing the array locations with a pointer/vector? For example:
    var “counter” = 13;
    var “ActState”= array[counter].state;
    #14342
    OPC UA driver in Rapid SCADA 6 can read arrays from the OPC server. On SCADA level each array element is stored in a separate channel. It’s easier to try and watch how it works.
    #14343
    BrainBranchetti99
    Isn’t it possible to multiplex the various channels into a single one using a pointer?
    #14355
    Could you provide an example?
    #14363
    BrainBranchetti99
    Ad example, i need to use on the html page a variable for example “motor state”.
    Now.. “MotorState” address is: motors[3].state
    If i have 10 motor to show, i need to replicate the variable address 10times.
    I prefer having a variable who indicate the actual motor that i need to show, for example “actual motor number” and with the change of this number change the address in to the plc.
    #14374
    If an OPC UA server provides motor states as an array, you can read them as an array and store in a single channel having length 10. But in the scheme view, you need to address channels by their numbers. Provide screenshots of the settings for more details.
