communicator not taking over the CPU.
Sorry, I didn’t catch what the error is?
MikhailModeratorPlease download Rapid SCADA again and update SCADA-Web application. Is it possible to just overwrite the files from ScadaWeb.zip
MikhailModeratorI observed this also, is there a reason it starts up minimised to the tray?
Let me think about it 🙂
MikhailModeratorAre the requested files here C:\SCADA\ScadaWeb\config\ ?
Do use use default installation directory C:\SCADA ?
MikhailModeratorThe beta version of the new schemes will be released in the summer 2016. In the first time it will support the existing format of schemes. SVG will be supported a bit later. Bootstrap is used. New components such as gauges will be added in the same time as SVG.
Thank you for your patience 🙂
In Chrome:
It is collapsed to a tray icon after start. Look for it in the right botton corner of your desktop.
MikhailModeratorThe reports are in SpreadsheedML format. It is XML that can be opened by Microsoft Excel and by Libre Office.
MikhailModeratorIt’s great that you ask. The report allows to export minute data to excel is ready. It will be included in the installation package within a few days. It can be executed from the reports page and it is integrated with Chart Pro component.
For now you can choose begin and end dates of a period of a report. In case of requirements to choose a time, some development is needed.
MikhailModeratorIs there a free HMI/Scada free IMG repository available?
Not yet. I usually look for images in Google Images
How does Dinamic IMG works and what is the format for it?
It shows an image depending on Input channel value and its Conditions property.
You can use PNG and JPG image formats.How can i make new IMGs? Is it possible to use Inkscape-Sage?
Any image editor. I use Microsoft Visio. Inkscape is good, but you should convert images to PNG or JPG.
For example, is it possible to make a gauge that the pointer changes according to the input of a tag?
For now you should create a set of images with different levels and use Dynamic picture component. In the future such components will be developed.
MikhailModeratorAfter getting every block of data from Communicator, the calculated channels are updated. Could you describe the issue in details?
First of all, make sure that the web site on 192.168.0.12 is accessible: try to open http://192.168.0.12
If not, may be the cause is firewall.
MikhailModeratorThank you very much for the detailed research.
The fix is ready. Please send a letter to info -a- rapidscada.org, I will send you the fix to try.
MikhailModeratorBTW… schemes are working too! good job!
magic 🙂
MikhailModeratorI can’t reproduce the error. Could you set active only one device and only one element group in the template? Then post a part of log and the displaying values as you did.
After polling you should stop Communicator and then look for displayed values to avoid their change.
MikhailModeratorI will check today.
