Forum Home › Forums › Installation Issues › I cant see Scada Comunicator window
- This topic has 9 replies, 3 voices, and was last updated 10 years, 5 months ago by
April 26, 2016 at 5:54 pm #1016
MR-Ing
ParticipantHello.
I run Scada Comunicator, but I can´t see the window. If I run again , a message said that already running , but I can not see the screen.
I am following the step by step for connecting devices using modbusThanks for your help
April 26, 2016 at 6:23 pm #1017
It is collapsed to a tray icon after start. Look for it in the right botton corner of your desktop.April 26, 2016 at 8:03 pm #1020C_D
ParticipantI observed this also, is there a reason it starts up minimised to the tray?
April 26, 2016 at 8:40 pm #1021MR-Ing
ParticipantThank you. I could continue the example until I had to run scada web configurator and leave the following errors:
\ SCADA \ ScadaWeb \ config \ CommSettings.xml not foud
\ SCADA \ ScadaWeb \ config \ WebSettings.xml not foud
\ SCADA \ ScadaWeb \ config \ ViewSettings.xml not foudDirectly config folder does not exist.
April 27, 2016 at 6:56 am #1022
MikhailModeratorAre the requested files here C:\SCADA\ScadaWeb\config\ ?
Do use use default installation directory C:\SCADA ?April 27, 2016 at 6:57 am #1023
MikhailModeratorI observed this also, is there a reason it starts up minimised to the tray?
Let me think about it 🙂
April 27, 2016 at 7:55 pm #1045MR-Ing
ParticipantHi Mikhail.
…”Are the requested files here C:\SCADA\ScadaWeb\config\ ?…”
No. There is no folder called Config. The only folder in ScadaWeb is aspnet_client
I can not find the .xml files in the directory SCADA…”Do use use default installation directory C:\SCADA ?…”
YesBut I remember in item 6 of the installation guide , could not move because I said that ScadaWeb folder does not exist. Then to create the folder , but scadasetup.exe ejecurar there was a conflict in the ScadaWeb folder.
Greetings and thanks.
April 28, 2016 at 7:18 am #1052
MikhailModeratorSCADA-Web is installed incorrectly. Try reinstall SCADA-Web. If the installer shows error, post it here.
May 2, 2016 at 4:45 pm #1070MR-Ing
ParticipantHi..
I did not know how to install only ScadaWeb . Then unzip ScadaWeb.zip directly in the folder C :/SCADA/ScadaWeb and now everything works without error.Thanks for everything.
May 3, 2016 at 5:52 pm #1072
MikhailModeratorI did not know how to install only ScadaWeb
You can choose checkboxes in the installer.
Anyway you have installed it 🙂 -
