MikhailModeratorTested on Raspberry Pi – OK.
MikhailModeratorscada_web_beta.zip has been updated. Added commands and acknowledgement functionality.
In case of any bugs, please, write on the forum.
MikhailModeratorWow π
MikhailModeratorIs it possible to install .NET 4 in parralel with 4.5?
Something wrong with WCF Activation, which is a part of .NET 4 in Windows 7, but installed separately in Windows 8+.What is shown by the link http://localhost/scada/scheme/ScadaSchemeSvc.svc ?
MikhailModerator
MikhailModeratorPost a screenshot of your installed Windows features that includes WCF node.
See this topic
What Windows version do you use?
MikhailModerator1. Use Server shell -> Files -> Current Data
2. Via the web app
MikhailModeratorWise π
You have to set Multiple command checkbox, if the device manual specifies 0x0F or 0x10 command codes. Element count – number of registers set by a single command.
What is the difference between
They must be the same for a command. Command number binds a template with a sent command.
Further, what βValueβ should I send?
Depending on your device. See the device manual.
I think, you should grant write rights on C:\SCADA\ScadaWeb\config folder for the user that specified in the wep app log.
MikhailModeratorCheck the following:
– Use SCADA-Server checkbox and Bound checkboxes are set ON in Communicator;
– Input channels have valid signals;
– Database are passed to Server by Administrator app;
– Server and Communicator are restarted after reconfiguring.
MikhailModeratorYes, the software is permanently improved.
MikhailModeratorYou should create a new topic on Understanding the Software subforum. There is no RPi specifics.
MikhailModeratorInstall MSSQL Compact from the distributive:
both
SSCERuntime_x86-ENU.msi and
SSCERuntime_x64-ENU.msi -
