Device Template Editor Question
Forum Home › Forums › Communicating with Devices › Modbus › Device Template Editor Question
  • #1468
    janeoh
    Good day,
    Under “MODBUS, Device Template Editor”, I have set up a command (Name, Data table, Element address, Command number).
    What is the “Multiple” and what is “Element count” for command? I don’t see extra items appearing.
    Another question:
    What is the difference between the “Command number” from “MODBUS, Device Template Editor” and the “Command number” from Commands in “SCADA-Communicator”? Further, what “Value” should I send?
    • This topic was modified 10 years, 4 months ago by Mikhail.
    #1470
    You have to set Multiple command checkbox, if the device manual specifies 0x0F or 0x10 command codes. Element count – number of registers set by a single command.
    They must be the same for a command. Command number binds a template with a sent command.
    Depending on your device. See the device manual.
    #1471
    janeoh
    Good day,
    Thanks for replying.
    The Address for the Command Code is 00A0h. The Hex Address is 00A0, with a Range of Low = 1 and High = 12.
    Command Code Function Modbus Function Code
    01 Open 06h, 10h
    02 Close 06h, 10h
    03 Reset Targets 06h, 10h
    04 Trigger 06h, 10h
    … etc. up to Command Code 11
    How do I interpret this from the device manual? What do I put in the “MODBUS, Device Template Editor”? What do I give as a value?
    The manual says that 06h, 10h are the “Modbus function code used to initiate the related command code”
    Thanks,
    Jane Oh
    #1472
    janeoh
    Good day,
    Thanks! I’ve got it!
    I just left the Multiple unticked and set the Command Number to 1.
    Regards,
    Jane Oh
    • This reply was modified 10 years, 4 months ago by janeoh. Reason: Clarity
    #1475
    Wise 🙂
