WCF Service error
Forum Home › Forums › Uncategorized Issues › WCF Service error
Viewing 14 posts - 1 through 14 (of 14 total)
  • #68
    teleco
    Once I have logged to some account, when I try to visualize the default scheme, the next error appears:
    WCF service error: [HttpWebRequest_WebEXception_RemoteServer]
    Argumentos: NotFound
    Las cadenas de recursos de depuración no están disponibles. La clave y los argumentos suelen proporcionar suficiente…
    How can I solve it?
    #71
    The error is concerned with a security reason. Scheme is displayed by the silverlight application which can’t connect to WCF service.
    Try to open SCADA-Web using different URLs:
    http://localhost/scada
    http://127.0.0.1/scada
    http://YourComputerName/scada
    Does it solve the problem?
    #601
    sancudo
    I’m having the same problem, opening SCADA-Web with the different URLs suggested didn’t work for me. It throws the same error anyway.
    Are there any other alternatives to solve this?
    #602
    Is there any additional information in the log files in the folder C:\SCADA\ScadaWeb\log ?
    #604
    sancudo
    The ScadaScheme log provides no information. The only thing in ScadaWeb that could be something is this, which i’m not sure what kind of file it is.
    2015-10-13 06:27:29 <MYCOMPUTER><DefaultAppPool><ACT> SCADA-Server unable to open file [Ev]\e151013.dat
    Only log before that is me login in. Not sure if this has something to do with it. When I attempt to load the default scheme and get the error, no lines are added to the log file but the time of that is not far off from about 5 minutes from one of the times when I got the error.
    I get an error 404.3 when trying to Access the .svc like that.
    • This reply was modified 11 years ago by sancudo.
    #608
    Most likely Microsoft WCF does not work on your computer.
    Try the following recomendations: http://stackoverflow.com/questions/6425442/http-error-404-3-not-found-in-iis-7-5
    Be attentive: you need WCF 4 or higher
    #609
    sancudo
    Well, seems I made some progress, now I’m getting this error
    WFC servie error: [ResponseContentTypeMismatch
    Arguments: text/html; charset=utf-8,text/xml; charset=utf/8,1024,
    <!DOCTYPE html PUBLIC “-//WC3//DTD XHTML 1.0 Transitional//EN” “http://www.w3.org&#8230;
    The ScadaWeb.log throws this as the associated error
    2015-10-13 14:55:39 <MYCOMPUTER><DefaultAppPool><EXC> Application error: Path ‘/Scada/scheme/ScadaSchemeSvc.svc’ is forbidden.
    at System.Web.HttpForbiddenHandler.ProcessRequest(HttpContext context)
    at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
    at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    Page: http://localhost/Scada/scheme/ScadaSchemeSvc.svc
    And trying to access directly to the .svc throws this in the browser
    Any way to enable the access? is it because of firewall or is there another reason?
    #612
    I don’t think that Firewall blocks the page. The cause is in ASP.NET, IIS and WCF.
    What Windows version do you use?
    #613
    sancudo
    Windows 8.1
    #614
    Probably something wring with a handler for *.svc like written here, here and here.
    I can try to solve the issue remotely, but it is a payable service (in case of success))
    #615
    sancudo
    Managed to solve it by using DSIM in the command prompt in one of the replies of the first link.
    After aplying that I started getting the following error
    Server Error in ‘/Scada’ Application.
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: The value of the property ‘controlRenderingCompatibilityVersion’ cannot be parsed. The error is: Version string portion was too short or too long.
    Source Error:
    Line 4: <compilation targetFramework=”4.0″ />
    Line 5: <roleManager enabled=”true” />
    Line 6: <pages controlRenderingCompatibilityVersion=” ” />
    Line 7: </system.web>
    However, I fixed it by putting 4.0 instead of leaving line 6 blank which is the line of the error.
    Thanks for all the help and availability!
    #616
    Thanks for the solution! I hope it will help others.
    #1937
    MohanadOdema
    For the problem WCF service error: [HttpWebRequest_WebEXception_RemoteServer]
    Arguments: NotFound.
    This solution did not work for me yet I’m adding another solution that I figured out during the course of a day in case someone is facing the same issue.
    I’m using Windows 7 sp1 for the record. After I had installed the .NET framework v4.0, I ran the cmd program as an administrator and typed the following:
    cd C:\Windows\Microsoft.NET\Framework\v4.0.30319\
    Next I typed: aspnet_regiis.exe -i
    These steps make sure that the IIS is actually working with version 4 of .NET.
    Regarding the “not found arguments”, I opened Scada\ScadaWeb\Web.config and found that the argument behavior name is nullified so I initialized it to “a” and I was finally able to load my scheme from the web browser.
