Channel column in Device data is empty
Forum Home › Forums › Understanding the Software › Channel column in Device data is empty
  • #1462
    MohanadOdema
    I have a problem in the Scada Communicator. The channels are not bound to their device tags even though I created the required channels from services/create in Scada Admin with the appropriate signals to match those in the template of my device in the ScadaComm.
    I’m using Modbus and The device ID and communication line ID are matched in both the ScadaComm and ScadaAdmin.
    #1463
    Check the following:
    – Use SCADA-Server checkbox and Bound checkboxes are set ON in Communicator;
    – Input channels have valid signals;
    – Database are passed to Server by Administrator app;
    – Server and Communicator are restarted after reconfiguring.
