MikhailModeratorHola
00 00 00 00 00 06 F6 03 00 00 00 05
F6 is a unit ID, in terms of Rapid SCADA this is a device address defined in Administrator.
While another software uses Unit ID = 1.
You can check it by http://modbus.rapidscada.net/First of all, change the device address to 1.
MikhailModeratorI suppose, you should provide links to screenshots of your settings and copy communication log here.
MikhailModeratorI can connect to your PC remotely and fix the issue. This is a commerical service. To get it, please contact us by email.
MikhailModeratorHow can I do this?
For example, Cnl * 10
is it possible to implement a digital momentary start/stop?
Please clarify the question.
MikhailModeratorRapid SCADA requires .NET Framework 4.6 or higher. You need at least Windows 7. See this
MikhailModeratorThere was no changes in the project format. To get more error details, press F12 in a browser and watch the Console tab.
MikhailModeratorI’m afraid that Windows XP is too old. You can’t install .NET Framework 4.6 on XP that is required for Rapid SCADA.
After the update,paste the old project.
Did the problem appears only when you apply the old project? Does it work after clear installation?
MikhailModeratorThanks for the solution ))
Also the web site referenced in the install_with_apache.txt file does not resolve
That’s true. That’s why there is a ready file scada.conf in the distributive package.
Check Commands enabled checkbox of a communication line. If it doesn’t help, copy communication line log here in a moment of sending command.
MikhailModeratorCan I do it for 2 conditions?
Yes.
a ? b ? c : d : eI forget how the above works ))
MikhailModeratorIn 2019 we may move to .NET 4.7, so you probably should think about upgrading the server OS.
.NET 4.7 is required to use the same .NET Standard DLLs with cross-platform .NET Core build of Rapid SCADA.
Press Ctrl+F5 to refresh all the scripts.
December 28, 2018 at 7:51 am in reply to: SCADAComm stop attempt to reconnect when communication failed #4790
MikhailModeratorIf you send me an email to info@ , I will forward your message to bersim.
You can try copying Web.config from the previous version. Does it help? -
