Viewing 15 posts - 4,156 through 4,170 (of 6,279 total)
  • in reply to: Error exporting to dB #5553
    This is strange, because there is no column named “Infinity” in your SQL requests. Do you have any idea where you can mention “Infinity”?
    Also ExportEvents tag contains false that means that “Error export events” should not be printed in any case.
    May be another configuration is running?
    in reply to: Installation Rapid scada on a Raspberry Pi #5552
    That’s good!
    in reply to: Table view #5551
    Table views uses hourly data.
    If you’d like to watch minute data use Minute Data Report or Chart Pro Plugin.
    in reply to: Installation Rapid scada on a Raspberry Pi #5545
    Check Mono version by the command:
    mono --version
    You should get something like 5.20.1
    in reply to: Error exporting to dB #5544
    Please make screenshots of the settings of the export module where SQL requests are shown.
    in reply to: Unable to Extract Data #5543
    Use http://modbus.rapidscada.net/ for decode.
    And you get that the device returns the error:
    [02] ILLEGAL DATA ADDRESS
    You should check the register address using the service mentioned above.
    in reply to: Installation Rapid scada on a Raspberry Pi #5539
    Do you use Apache?
    You should check the installation steps related to installing the web server.
    Currently Mono .NET Framework is not integrated with the web server.
    in reply to: Hide Main menu for guest or custom users #5538
    You can remove the plugins page if you deactivate the Store plugin.
    If you need to remove whole menu, programming required.
    in reply to: Hide Main menu for guest or custom users #5533
    It doesn’t depend on a user role.
    in reply to: Hide Main menu for guest or custom users #5532
    You can:
    1. Click “Collapse menu” in the bottom left.
    2. You can use Full Screen mode. The button is in the top right corner.
    in reply to: map plugin #5530
    Do this instructions step by step. If something goes wrong, ask here.
    in reply to: OPC Server Connection – E_NETWORK_ERROR #5528
    1. What OPC server do you use?
    2. Does it work before with Rapid SCADA?
    3. Does it work before with Rapid SCADA on the same computer?
    4. Did you install OPC Core Components?
    5. Does Matrikon OPC Simulation server work on this computer?
    in reply to: Inactivation of Elastic report #5525
    You have to write @ElasticRep instead of @ElasticReport in the row with ID 16
    in reply to: Inactivation of Elastic report #5520
    Screenshot of the Interface table is missing.
    in reply to: Export to DB – String variables #5519
    The idea of conversion:
    Convert the value of double type to 8 bytes. Each byte is a character.
    public static string DecodeAscii(double val)
        byte[] buf = BitConverter.GetBytes(val);
        return Encoding.ASCII.GetString(buf).TrimEnd((char)0);
    You should create a function in your database that performs this conversion.
