Export to DB – String variables
Forum Home › Forums › Uncategorized Issues › Export to DB – String variables
  • #5514
    JD
    I am using the Export to DB module, attached to a MySQL database.
    I have a tag which is a string (ASCII Text on SCADA-Administrator) that is displayed correctly on the web station.
    On the MySQL database it is shown as float and thus has no sense. How can I log it to string type or at least how can I decode the stored float value to the expected string? CONVERT and CAST functions of MySQL do not work.
    #5519
    The idea of conversion:
    Convert the value of double type to 8 bytes. Each byte is a character.
    public static string DecodeAscii(double val)
        byte[] buf = BitConverter.GetBytes(val);
        return Encoding.ASCII.GetString(buf).TrimEnd((char)0);
    You should create a function in your database that performs this conversion.
