Hide Main menu for guest or custom users
Forum Home › Forums › Development and Integration › Hide Main menu for guest or custom users
  • #5531
    denniso
    Is it possible to hide the main menu in the left corner for certain roles?
    #5532
    You can:
    1. Click “Collapse menu” in the bottom left.
    2. You can use Full Screen mode. The button is in the top right corner.
    #5533
    It doesn’t depend on a user role.
    #5537
    denniso
    Dear Mikhail,
    Thank you for your answer.
    I wanne hide the menu completely or online the plugins etc page. Is this easy possible or do i need this remove from the coding?
    Many thnx Dennis!
    #5538
    You can remove the plugins page if you deactivate the Store plugin.
    If you need to remove whole menu, programming required.
