Forum Home › Forums › Uncategorized Issues › Error exporting to dB
- This topic has 11 replies, 2 voices, and was last updated 7 years, 4 months ago by
June 12, 2019 at 10:43 am #5542
robybob
ParticipantHi there,
thanks for your great Scada. I am using 5.6.1 rapidscada.
Well I am exporting data, coming from Modbus to MySQL db but for some reasons I am getting an error (detected from ModDBExport.log) that I am not able to address the source:
– Error export events to DB MySQL – x.x.x.x: Unknown column ‘Infinity’ in ‘field list’
This is annoying and it is filling log directory in a few days but it is not impacting on importaed data.
In any case I woudl like to rid off of it, would you be so kind to drive me in finding a solution ?
Regards
RobybobJune 12, 2019 at 3:18 pm #5544
Please make screenshots of the settings of the export module where SQL requests are shown.
June 13, 2019 at 5:51 am #5550robybob
ParticipantHi Mikhail,
I am sorry to bother you again.
Well, server where the error is present is Ubuntu, so I can post you the XML
of the Server:<?xml version="1.0" encoding="utf-8"?> <ModDBExport> <ExportDestinations> <ExportDestination> <DataSource> <DBType>MySQL</DBType> <Server>192.168.20.50</Server> <Database>rapid</Database> <User>ScadaServerCtrl</User> <Password>rapidscada</Password> <ConnectionString /> </DataSource> <ExportParams> <ExportCurData>true</ExportCurData> <ExportCurDataQuery>INSERT INTO cnldata (datetime, cnlnum, val, stat) VALUES (@dateTime, @cnlNum, @val, @stat)</ExportCurDataQuery> <ExportArcData>true</ExportArcData> <ExportArcDataQuery>INSERT INTO cnldata (datetime, cnlnum, val, stat) VALUES (@dateTime, @cnlNum, @val, @stat) ON DUPLICATE KEY UPDATE val = @val, stat = @stat</ExportArcDataQuery> <ExportEvents>false</ExportEvents> <ExportEventQuery>INSERT INTO events (datetime, objnum, kpnum, paramid, cnlnum, oldcnlval, oldcnlstat, newcnlval, newcnlstat, checked, userid, descr, data) VALUES (@dateTime, @objNum, @kpNum, @paramID, @cnlNum, @oldCnlVal, @oldCnlStat, @newCnlVal, @newCnlStat, @checked, @userID, @descr, @data)</ExportEventQuery> </ExportParams> </ExportDestination> </ExportDestinations> <ManualExport> <CurDataCtrlCnlNum>1</CurDataCtrlCnlNum> <ArcDataCtrlCnlNum>2</ArcDataCtrlCnlNum> <EventsCtrlCnlNum>3</EventsCtrlCnlNum> </ManualExport> </ModDBExport>If this is not sufficient, I might find out the original rapid scada server configuration and forward Config screenshots.
Let me know
RobybobJune 13, 2019 at 12:51 pm #5553
MikhailModeratorThis is strange, because there is no column named “Infinity” in your SQL requests. Do you have any idea where you can mention “Infinity”?
Also ExportEvents tag contains false that means that “Error export events” should not be printed in any case.
May be another configuration is running?
June 13, 2019 at 1:22 pm #5554robybob
correct, I have switched off events in order to find out who is causing the error in error log. I don’t have any clue where clause ‘Infinity’ is coming out and I would add a similar error coming out with ‘NaN’ instead of ‘Infinity’.
I doubt there are other configurations running but I will check out in the case I left some residuals from a previous installation.
I may add some more information:
– mysql dB is running in the same HW where rapidscada is located, when upgrading to 5.6.1 from 5.6.0 (where no errors where present) I rebuild completely ServerComm configuration (modbus) in order to respect your document and indications.
– mysql log doesn’t state any import error (maybe I need to activate verbosity to get it).
Latest: another error is coming out
Unable to enqueue an event. The maximum size of the queue 100 is exceeded
Is there a way to enlarge output queue ?June 14, 2019 at 5:49 am #5555robybob
ParticipantHere you are,
well I have increased the delay to 2000 ms but I am getting a queue overflow:`2019-06-14 05:41:59 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 05:46:28 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 05:48:52 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 06:20:54 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 06:22:30 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 06:38:36 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 06:39:02 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 07:18:05 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 07:25:46 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 07:32:59 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
Do you think I am getting a performance issue of rapidscada ?Regards
RobybobJune 14, 2019 at 4:13 pm #5557
Likely the queue size is exceeded because of the error executing the request. What is the full situation in logs currently?
I could connect to your machine remotely and research for the cause, but this service is out of free support.June 15, 2019 at 7:27 am #5558robybob
ParticipantWell Mikhail, thank you for offering a remote connection, but I would need an official offer for support and costs in the case.
In the time between I might give a more clear idea what there is behind this issue:
– scadaComm has 7 Modbus channels. Each channel has about 60 elements to interrogate and gather values. Elements are grouped into 12 element group and delay between each group interrogation is 2 secs. Finally delay per each sequence is 30 sec.Well, according log, ScadaComm starts regularly without any alarm, after about 4 hours a first queue overflow alarm is coming out. Then the alarm frequency increases.
`2019-06-14 08:20:57 Start ModDBExport module
2019-06-14 08:24:05 Module ModDBExport is stopped
2019-06-14 08:24:07 Start ModDBExport module
2019-06-14 11:04:07 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:07:32 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:08:50 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:15:20 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:16:39 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:17:57 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:19:15 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:20:33 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:22:58 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:24:16 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:25:34 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:26:52 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:29:39 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:30:47 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:33:23 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:33:33 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:34:51 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:35:59 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:36:07 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:38:23 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:38:45 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
2019-06-14 11:41:38 Unable to enqueue an event. The maximum size of the queue 100 is exceeded
`So I might deduct (maybe wrongly) that problem could be in performance and/or is queue too short for my implementation.
BTW you should have my email where to write your offer for remote support/assistance.
Thank you so much
RobybobJune 16, 2019 at 10:19 am #5559
MikhailModeratoryou should have my email where to write your offer for remote
Please send email again to let me identify you correctly ))
Your description is clear, but watching the process is more efficient.June 16, 2019 at 10:20 am #5560
MikhailModeratorafter about 4 hours a first queue overflow alarm is coming out
A long time needed for exceeding the queue size means that simple increasing the queue size doesn’t solve the issue.
June 17, 2019 at 6:28 am #5561robybob
sure, you are perfectly right concerning that increasing size of queue will not solve the problem, but it might help in delaying it. It would be just a temporary workaround as I am afraid that after a few days, process stucks and stops sending data (as it was before changing delays).
BTW my email is: … and I will be waiting for your email.Regards
Robybob-
This reply was modified 7 years, 4 months ago by
June 17, 2019 at 8:15 am #5563
I’ve sent an email. -
