Viewing 15 posts - 3,451 through 3,465 (of 6,288 total)
  • in reply to: HTTPS endpoint #7686
    1. Download the web.config files and overwrite the existing in C:\SCADA\ScadaWeb\
    2. Enable HTTPS on IIS. Link
    3. Install SSL certificate if you use domain.
    in reply to: Database MySQL usage #7685
    An input channel can store only 8 Latin characters, because channel value size is 8 bytes. SCADA mostly works with numbers than strings.
    in reply to: Integration with IAP #7684
    You should learn the existing source code of the Login.aspx page, understand it, and then implement your own.
    in reply to: Elastic Report Flexibility #7682
    Please provide the report example.
    Elastic Report allows to set a reading hour.
    in reply to: Server is unavailable #7681
    The Agent service doesn’t work. If you need more info, create a new topic.
    in reply to: Website Artical section is down, can’t access dev guides #7673
    Thank you. We will check and fix it.
    in reply to: Automatic Control Module integration #7672
    Just copy the module files into /opt/scada/ScadaServer
    Do you configure Rapid SCADA on RPi4 using Windows?
    in reply to: Send command #7666
    You should try to download and setup the module. If you have questions during this process, please ask.
    in reply to: Send command #7665
    That means Press the Button, the value will be 1, released the Button, past some second, the value auto will be 0. I do likes that, don’t i?
    I also would choose this method.
    When a user click the button, the 1st command is sent. Then you need Automatic Control Module that triggers on the 1st command and automatically sends the 2nd command after the specified delay.
    in reply to: Questions regarding formular #7664
    Messages are sent in UTF8. It’s here. If you provide a particular example, we can check it here.
    in reply to: Questions regarding formular #7663
    It always tell me the you look like spam
    The is a protection plugin in the forum. The used rules like a back box. Without the plugin, there would be plenty of spam messages.
    in reply to: Storing the result of a formula with Database Import Driver #7660
    Is there a way to store data in a database automatically over time , without a prompt?
    You should use DB Export Module of SCADA-Server instead of DB Import driver.
    If I understood this correctly, the only way to save data is by sending a command, isn’t it?
    It’s true for DB Import Driver.
    • This reply was modified 5 years, 6 months ago by Mikhail.
    in reply to: ChartPro on IE11 Win10 #7659
    On my Win10 machine Edge was automatically replaced to the new Chrome-based version.
    Thank you for the script.
    in reply to: How to Use Dashboard plugins #7658
    You can change AspectRatio parameter that affects height. But it doe not resize vertically automatically.
    Try using WebPage view if you need only 1 chart on a page.
    in reply to: Acces the Modbus data from outside the LAN #7657
    And you need configure a router to forward the incoming requests to your Rapid SCADA server.
