Storing the result of a formula with Database Import Driver
Forum Home › Forums › Understanding the Software › Storing the result of a formula with Database Import Driver
  • #7630
    David01
    I am using a database to store data from Rapid Scada. I want to save the value of an input into a table.
    In order to do this, I have created an output with a formula that references the value I want to save. It has the same command number as that the one I defined in the driver. The problem is that, when I send a command, the value saved is whatever value is written in the command, instead of the result of the formula.
    The SQL code I am using for the command is:
    INSERT INTO data (Counter1) VALUES (@cmdVal);
    So, my question is: How can I write the result of a formula in a MySQL database?
    • This topic was modified 5 years, 10 months ago by Mikhail.
    #7634
    Do you use Database Import Driver?
    #7635
    Please provide screenshots that illustrate your settings and system behavior.
    #7642
    David01
    Yes. I am using Database Import Driver.
    I managed to make it work on my own. I think I had done something wrong with the configuration. I am sorry for the trouble.
    Now I have another question: Is there a way to store data in a database automatically over time , without a prompt?
    If I understood this correctly, the only way to save data is by sending a command, isn’t it?
    #7652
    David01
    Also, is there a way to store multiple data in a single sql table with a single command?
    The documentation references the cmdVal variable, but that only sends the value of the current command. So, what if I need to store several variables?
    For example, table1 has two columns: variable1 and variable2. I can use an SQL query like this:
    INSERT INTO table1(variable1, variable2) VALUES (@cmdVal, null)
    I can only pass the data for variable1, that’s why I am forced to pass a null value to variable2. Do I need to create an aditional command to write variable2 on the table?
    #7660
    You should use DB Export Module of SCADA-Server instead of DB Import driver.
    It’s true for DB Import Driver.
    • This reply was modified 5 years, 10 months ago by Mikhail.
    #7662
    David01
    Thank you. I will look into it.
