HTTPS endpoint
Forum Home Forums Understanding the Software HTTPS endpoint
Viewing 10 posts - 1 through 10 (of 10 total)
  • #7674
    mark9966
    HI,
    how can i enable https in both windows and linux scenario?
    Thanks.
    #7677
    mark9966
    Good morning,
    At the moment i need to enable it on WIn.
    #7686
    1. Download the web.config files and overwrite the existing in C:\SCADA\ScadaWeb\
    2. Enable HTTPS on IIS. Link
    3. Install SSL certificate if you use domain.
    #7704
    mark9966
    Tried that solution but both trying local and public access goes to error https://postimg.cc/gnQRMb5F. What am i missing?
    #7705
    Does https://localhost work?
    #7714
    mark9966
    No it doesn’t.
    #7716
    Sergei
    Please note the web.config file in ScadaWeb\plugins\Scheme also needs to be edited for HTTPS to work corectly. Else the schemes cannot be grabbed by the plugin. (The console -F12- shows “404 not found” errors)
    #7717
    Sergei
    Also, please note that after enabling HTTPS in IIS, https://localhost will not work (and should not) because the SSL certificate is for the public domain name and most probably doesn’t include the localhost domain.
    #7718
    No it doesn’t.
    So the current issue is related to IIS configuring, not Rapid SCADA. I suggest watching some videos in the internet how to setup HTTPS on IIS. Also we can configure IIS for a fee.
    #7719
    The archive I mentioned above, contains all web.config files needed for the web app and plugins.
