Viewing 15 posts - 2,461 through 2,475 (of 6,289 total)
  • in reply to: server is unaviliable #10611
    You should check that the directories specified in the project for the Server application, actually exist on the disk.
    in reply to: TCP Client Modbus RTU #10610
    To reduce the list of combinations, describe what result do you need.
    in reply to: Device channels not reconized in v6 #10609
    For some reason, channel generation for MQTT client has not been implemented yet.
    You should create channels manually. Copy channel properties from Simulator channels.
    Thank you for reporting this issue.
    We will implement the feature for MQTT channel generation with a priority, and I will let you know about it in this topic.
    in reply to: Modbus Slave Driver – No computer code found #10593
    The app started at 19:33, but errors occurred at 15:18. Therefore, they don’t matter.
    in reply to: Scheme support #10592
    Add a led component to a scheme, and set its Input channel property to the particular channel.
    in reply to: Units to be displayed #10589
    Units are displayed on schemes, and not displayed in table views.
    in reply to: Reading Day in Elastic Report #10588
    I see that there is “average” column inside the input channel description table? May I know what is the meaning of average here?
    See the example.
    in reply to: Reading Day in Elastic Report #10587
    We can directly type formulas in that xml file or we have to do calculations only in excel after exporting?
    You can insert formulas in the XML. ElasticRepExample.xml contains an example:
    <Column name="Summary Consumption" calcType="Formula" value="=SUM(RC[-3]:RC[-2])" calcTotal="true" colStyle="col-lg" />
    in reply to: Command error #10586
    To check the settings, you should provide screenshots of the settings.
    in reply to: Plug in charge #10585
    If a trial key is expired, you can get a new daily trial key for free.
    in reply to: Formulas for Rapid Scada #10584
    in reply to: Report in excel #10583
    Table views and events can be exported to Excel out of the box. It’s free.
    in reply to: Units to be displayed #10582
    Click the Refresh data button above the edited table.
    in reply to: Rapid SCADA 6 Beta #10581
    in reply to: Hide “Main Menu” in v6 #10580
    Yes. In Administrator open your project, open ScadaWebConfig.xml and set ShowMainMenu to false. Then upload the project.
