I try to add a command for channel 102 with command number #2 and it does not work at webstation interface. But for channel 101, it works on this using command 1. The test is to use a command to input a value under register 40001 for channel 101 and 40002 for channel 102. It works for channel 101 only. Please advise if my step is not correct here.
