MikhailModeratorThank you for the update.
MikhailModeratorRapid SCADA 6.4.4 has been released.
This is a maintenance release required for further development of the system.
– Minor bugs have been fixed.
– Reports now display the name of the user who generated the report.Useful link:
All commercial modules in a single archive.December 19, 2025 at 2:08 pm in reply to: OPC DA to OPC UA pipeline: “uncertain” tags are becoming “BAD” #17435
MikhailModeratorI suppose, it’s better to fix the OPC server to get GOOD values.
Alternatively, you can change the source code of the driver to solve this certain issue for your needs. There is no plan to change the driver for all users, because “uncertain” means that data is not good.-
This reply was modified 5 months ago by
December 19, 2025 at 2:04 pm in reply to: How to send commands to an OPC DA server via an OPC DA → OPC UA gateway #17434
Please don’t post AI slop on the forum.
Please ask questions using your own mind.
Providing screenshots can help save time and get better answers.
Please open the developer tools in browser (press F12), and check if there any errors.
Also make sure that you selected PlgChartPro in the Webstation settings (in the Administrator app).
MikhailModeratorConfigure the components to display a chart on click. Then click them to display charts and check channel numbers.
Please provide screenshots.December 18, 2025 at 2:14 pm in reply to: OPC DA to OPC UA pipeline: “uncertain” tags are becoming “BAD” #17426
The OPC Classic driver requires GOOD quality to display data as valid. Otherwise, it marks the tag as undefined. Undefined tags are provided to OPC UA with BAD quality.
MikhailModeratorYou can mix periodical writing and writing on change. If you published a screenshot of the archive options, I could advice.
Also I suggest to enable events for those channels.
MikhailModeratorNote that you need some intermediate points to draw a chart.
MikhailModerator> I am currently archiving to an PostgreSQL database.
If so, just configure the archive options.
Historical archives of the default type save data with fixed period.
To save data on change, enable PostgreSQL archives. They are disabled in the HelloWorld project. Archives can be found and configured in Instances – Default – Server – Archives.December 15, 2025 at 10:56 am in reply to: Need download link for Rapid SCADA 5.1.x (Windows) #17411
I’ve added the updated links here.I suppose, you should check the errors in communication line log. Maybe configure communication channel manually.
MikhailModeratorProjConv5to6_dotnet8
HistConv5to6_dotnet8
EventConv5to6_dotnet8-
This reply was modified 5 months, 1 week ago by
December 12, 2025 at 12:08 pm in reply to: Rapid SCADA Migration to VMWare – No Chart Pro, Dashboard or Views #17407
MikhailModeratorTo discuss “The requested view is not specified”, an issue description should contain:
– only appropriate question
– corresponding screenshots and log files. -
