Cannot log into Rapid SCADA – New Installation
Forum Home › Forums › Installation Issues › Cannot log into Rapid SCADA – New Installation
  • #17386
    yotool
    I just installed the latest version of Rapid SCADA in a VMware workstation environment (twice). All Windows firewall rules are DISABLED on the VMWare host.
    I am unable to login to the web page at port 10008. localhost TCP/IP Port 80 displays the IIS default web page.
    https://photos.app.goo.gl/jyd25yiy6xVmnpXN9
    • This topic was modified 11 months, 3 weeks ago by Mikhail.
    #17390
    Please check this answer.
    #17391
    yotool
    Mikhail,
    You are the best.
    Your open-source software continues to impress the heck out of me.
    I am sorry to have wasted your precious time on such a stupid IIS .NET sub-feature problem that I should have already known about.
    All is well now, including the new VMWare hyper-virtualization option and importing a previous Rapid SCADA project from a base Windows 10 instance.
    I will post a new forum post on how I can properly buy a set of new Rapid SCADA set of licenses for the new VMWare VM.
    ..not sure of how you do the hardware hash for the Dashboard and ChartPro plugin in a VM…
    I am trying for backup portability using a virtual machine (*.ova in the case of VMWare).
    #17393
    Using virtual machines with Rapid SCADA is a good choice.
    #17399
    yotool
    Having now migrated the previous Rapid SCADA installation to a VMWare instance, I have a couple of issues.
    I copied the entire existing directory structure from the Windows 10 environment on the very same machine to the new VM Windows 10 directory structure and then “uploaded” it using the “Administrator” application.
    When I run “Communicator” from the new VM’s “Administrator” application it shows all of my Modbus channels (via TCP/IP) reporting successfully.
    However, when I go to the VM’s IP address of the VM using the default port of 10008, I get an error saying the “The application is not ready. Try again later.”
    But if I enter the user: admin and associated password, the Webstation screen shows correctly.
    Yet when the default web page is displayed, I now get “The requested view is not specified” error.
    The original Rapid SCADA installation had personal licenses installed for both the “Chart Pro” and “Dashboard” modules.
    Is this the reason for my data graph/view/dashboard errors?
    Thank you my friend.
    -Chet
    #17402
    Check the details in ScadaWeb.log
    Likely, it’s needed to wait the web app to start.
    Please create a new topic to resolve this issue.
