Forum Home › Forums › Installation Issues › Need download link for Rapid SCADA 5.1.x (Windows)
- This topic has 7 replies, 2 voices, and was last updated 11 months, 1 week ago by
tom040264.
December 7, 2025 at 4:51 pm #17385
tom040264
ParticipantHello,
I have a Raspberry Pi running Rapid SCADA 5.1.x (Webstation shows version 5.1.0.0).
I bought a new Windows laptop and now I need the old Windows tools (ScadaAdmin 5.x, SchemeEditor 5.x, etc.) to edit and upload the configuration. Unfortunately, I cannot find the old installation package.I can only find downloads for version 6, but it is not compatible with my Raspberry installation.
Where can I download Rapid SCADA 5.1.x for Windows?
A direct link or archive would really help.Thank you in advance
T.December 8, 2025 at 11:06 am #17388
Please send an email request to get the deprecated release. When you download the project, I strongly recommend to upgrade to the 6th version.December 9, 2025 at 12:29 pm #17397tom040264
ParticipantHello Mikhail,
Thank you for your reply. In the meantime, I found the package (from a very old backup).
BR
T.December 9, 2025 at 12:36 pm #17398tom040264
ParticipantAdditional question: where can I find the conversion tools? All links I have found in this forum are empty.
BR
T.December 10, 2025 at 1:18 pm #17401
Let me know what links are broken to repair them.
If your project < 1000 channels, I suggest to create a new project from scratch. It's possible to simply copy Modbus, OPC settings, and views.December 13, 2025 at 2:01 pm #17408tom040264
ParticipantHello,
I tried this one: https://forum.rapidscada.org/?topic=convert-historical-data-from-v5-to-v6#post-14299
Correction: not ALL links, as I wrote in my last message, but all I have found. 😉
I found the converter and converted my v5-project to the version 6. In the configuration I have 4 communication lines. Two of them work very well, but the other two have some troubles with the communiaction. Under SCADA v5 everything worked perfect.
The difference between the working lines and non working lines is the TransMode:
– working lines TCP
– non working lines RTUI have no idea what for should I look in this forum.
BR
T.December 15, 2025 at 10:56 am #17411
I’ve added the updated links here.I suppose, you should check the errors in communication line log. Maybe configure communication channel manually.
December 17, 2025 at 6:56 am #17417tom040264
ParticipantThank you. I converted my project from v5 to v6, and now everything works fine.
