MikhailModeratorAccording to the history that versions belong to Rapid SCADA earlier than 5.5.1 (March 16, 2018).
How many channels and devices in the project?
Try the Unicode sting data type instead of ASCII.
The images are stored in a scheme file. They are not loaded from some directory.
There is no a component to display a sequence of images. A possible method is using animated GIFs.
MikhailModeratorWhat application has a version 5.0.3.0?
This manual may help.
Can I find the old program version I used so far somewhere that I can at least restore the old state on the new server?
The oldest version that can be downloaded is 5.8.4.
You could simply copy C:\SCADA folder to a new server and register services as described in manual installation article.
MikhailModeratorSetting channel value doesn’t cause sending a command. Therefore the module is needed.
MikhailModerator🙂
You could try creating animated GIFs and using them inside Dynamic Picture components.
The above links don’t work.
June 19, 2023 at 10:24 am in reply to: Is it possible to display the hexadecimal characters of the input value? #12827
Decimal is a data type in C#. I suggest using another variable name.
Could you explain how it should work?
Grafana needs to retrieve historical data from an archive. You could put data into a historical archive with the required period.
Graphs can be opened in a different page.
For events, you could try the weird thing, in the Views table add a view with parameters:
View Type = Web page view
Arguments = /Main/Events
Then you can open all events as a view.
MikhailModeratorA toggle on a scheme generates commands depending on its value.
