New release Rapid SCADA 6.1.0
Forum Home › Forums › Installation Issues › New release Rapid SCADA 6.1.0
  • #12275
    A new release of Rapid SCADA 6.1.0 has been published.
    What’s new:
    – Added the Command format column to the Channels table
    – New faster application protocol
    – Module API has changed
    – Optimized archives
    Module and driver developers should recompile your modules and make changes to inherited method arguments as needed.
    #12291
    victorlam
    I have installed 6.0.0. May I know how can I install the 6.1.0?
    or I need to uninstall the whole version?
    #12292
    On Windows the installer provides the Update button. You could try update instead of uninstall/install.
    More info here.
    • This reply was modified 3 years, 7 months ago by Mikhail.
    #12353
    Rapid SCADA 6.1.1 has been released. It contains minor fixes. If 6.1.0 works well for you, no need to upgrade.
    #12611
    Rapid SCADA 6.1.2 has been released. It contains minor fixes. For the details see version history.
    Elastic Report plugin is now available for Rapid SCADA 6.
    #12842
    peter_f
    Hi
    I want to move Rapd Scada to another server. At the same time I want to update to the latest version. This is described in the documentation and should hopefully not be a problem. I use two paid plugins. Can I also move them, or do I have to purchase them again?
    Peter
    #12844
    Please check this page for information about transfer licenses.
