Is it possible to display the hexadecimal characters of the input value?
Forum Home › Forums › Understanding the Software › Formulas › Is it possible to display the hexadecimal characters of the input value?
  • #12819
    myscada
    I’m using V5.8.4. I have defined an array of characters in the formula (like ‘fixed char buffer[3];’), but got an error “CS0214: Pointers and fixed size buffers may only be used in an unsafe context”.
    • This topic was modified 3 years, 5 months ago by myscada.
    #12821
    myscada
    The following formular doesn’t work.
    public double HextoASCII(double decimal)
      string test;
      test = String.Format("{0:X}", decimal);
      return ScadaUtils.EncodeAscii(test);
    • This reply was modified 3 years, 5 months ago by myscada.
    #12823
    myscada
    it works now.
    test = String.Format("{0:X}", (int)decimal);
    #12827
    Thank you for the info.
    Decimal is a data type in C#. I suggest using another variable name.
    #12830
    myscada
    THX. I got the same error when uploading configuration.
