Is it possible to send 2 commands by one click?
Forum Home › Forums › Understanding the Software › Formulas › Is it possible to send 2 commands by one click?
  • #12831
    myscada
    I defined a function like the following
    public int test()
     SetVal(CnlNum, Cmd);
     SetVal(101, Cmd);
     return 0;
    “SetVal(CnlNum, Cmd)” works for the output channel where the formula is calculated. But “SetVal(n, Cmd)” works for the input channel “n”. How can I send a command to another output channel “n” ( where the formula is not calculated ) simultaneously? THX
    #12832
    You yourself wrote the formula how it is possible. If you need to send commands directly to the devices, then you need an automatic control module.
    #12834
    myscada
    THX. I will try automatic control module.
    #12839
    Setting channel value doesn’t cause sending a command. Therefore the module is needed.
