MikhailModeratorMake sure that you don’t ignore registration keys when upload the configuration. The checkbox must not be set.
https://ibb.co/RT4kMz6
Please provide more info related to the question.
Open the file C:\SCADA613\ScadaAgent\Config\ScadaAgentConfig.xml and check the Directory parameter. In your case, it should be C:\SCADA613\
After change ScadaAgentConfig.xml, restart the ScadaAgent6 service.
I want these to work well with all of Rapid SCADA’s components and possibly other components plugins .
It would be nice.
Could you advise on whether I should integrate these directly or if there’s an existing model I should follow?
Internal editor mechanism should be significantly updated to support such feature. The question is quite abstract.
MikhailModerator
Scheme Editor is a Windows application that interacts with a web page. Administrator permissions are required to open TCP port, so web page can get and send data to the application.
MikhailModeratorIs it possible to simply link Rapid Scada 6 to Influx DB Cloud?
Yes, it’s possible. Take into account that a free Influx DB cloud tier is very limited.
MikhailModeratorTry asking the author, @jurasskpark, on this forum or GitHub.
MikhailModeratorPlease provide screenshots.
MikhailModeratorYou should update ScadaInstanceConfig.xml
It was changed in the recent versions.
MikhailModeratorDB Import Plus includes additional features described in the driver docs. I haven’t tried this module by myself.
MikhailModeratorRapid SCADA 6.1.4 has been released. The changes mainly affected the web application and plugins.
Added new plugins:
– Store Plugin (included by default)
– Map Plugin: user can switch layers, plugin displays moving objects, marker labels and geometric shapes, supports custom marker icons.Thus, the work on porting modules to version 6 has been completed. The update is recommended for installation.
MikhailModeratorDo you mean DB Import Plus?
MikhailModeratorWhat was the cause of different ScadaAdmin behavior?
