July 8, 2024 at 9:24 am in reply to: Elastic report different default DateTime format for Excel #14909
Unfortunately, there is no such option.
MikhailModeratorWhat lines in ScadaServer.log after the Server service starts?
MikhailModeratorThank you for providing a solution.
Currently, there is only a basic option
Use TLS.
It would be useful to add more options such as providing certificate files.
I’ve added it to the wish list.July 5, 2024 at 10:18 am in reply to: Elastic report different default DateTime format for Excel #14896
MikhailModeratorIn Elastic Report, short date and time format is used. If you compare en-GB and en-US, you can see the difference.
MikhailModeratorLink example https://ibb.co/2cN8YGk
It’s in the Views table.
In Grafana settings, enable open in frames. By default it is disabled.
MikhailModeratorCould you make a screenshot of your CSV for demo mode?
MikhailModeratorJust copy the project folder. I recommend to use GitHub for storing your projects.
MikhailModeratorWhat do you get in ScadaWeb.log?
July 4, 2024 at 12:45 pm in reply to: Elastic report different default DateTime format for Excel #14884
SCADA\Config\ScadaInstanceConfig.xml
Another issue is not related to Elastic Report. Find a corresponding topic.Like in the “Minute Data Report”. Is this also feasible, or do I have to create a separate report for each group of values?
It’s supported in v6.
July 3, 2024 at 10:58 am in reply to: Elastic report different default DateTime format for Excel #14871
It may depend on Rapid SCADA culture that is set in the Administrator application.
MikhailModeratorIf you use default Rapid SCADA archives, copy the archive data files for backup.
MikhailModeratorAnd about demo mode ? What’s the trick to make the driver read data ?
It is useful to simulate a device with your data.
