Elastic report different default DateTime format for Excel
Forum Home Forums Understanding the Software Elastic report different default DateTime format for Excel
Viewing 10 posts - 1 through 10 (of 10 total)
  • #14862
    kcks66
    Hi Mikhail,
    My elastic report after generated excel datetime default is [02/07/2024 10:00:00].
    How to make default format after generated to become [Tue, 2 Jul 2024 10:00:00 AM]?
    #14871
    It may depend on Rapid SCADA culture that is set in the Administrator application.
    #14873
    kcks66
    Hi Mikhail,
    Pls advice for which file or location contain the culture or locale setting?
    #14884
    SCADA\Config\ScadaInstanceConfig.xml
    #14885
    kcks66
    Hi Mikhail,
    I change the culture from original en-GB to many such as en-US, en-SG, en-MY, etc. Somehow I can get is [7/2/2024 10:00:00 AM]. I still couldn’t get [Tue, 2 Jul 2024 10:00:00 AM].
    If I manually change the DateTime inside Excel Format Cell by using custom code [ddd, d mmm yyyy hh:mm:ss AM/PM], it worked.
    Pls advice for can I use something like [ddd, d mmm yyyy hh:mm:ss AM/PM] into Rapid SCADA Administrator application to make it happen?
    #14889
    JurasskPark
    @kcks66
    Display of the time format (if the OS is Windows) depends on the setting Control Panel – Regional Options – Advanced Options – Date tab – Date format – full date format.
    What can you choose there?
    #14896
    In Elastic Report, short date and time format is used. If you compare en-GB and en-US, you can see the difference.
    #14905
    kcks66
    Hi JurasskPark,
    I can choose as below:
    https://ibb.co/FJTsfkb
    #14906
    kcks66
    Hi Mikhail,
    Can I change from short date and time to long date and time in Elastic Report?
    #14909
    Unfortunately, there is no such option.
