Integrate external grafana and DB to rapidscada v6
Forum Home › Forums › Development and Integration › Integrate external grafana and DB to rapidscada v6
  • #14887
    ptruffa
    Hello
    I am trying to connect rapidscada v6 with grafana cloud and external postgresql database.
    Between RS and PGDB I can use the ModArcPostgreSql module, so should not be a problem.
    Between grafana cloud and PGDB there is no problem either.
    But between RS and grafana I couldn’t make it. I use Extra Scheme Components, set the URL that I got from the share option in the grafana panel. And the connection to the dashboard is refused.
    I think that is ok because to access to dashboard need to login to grafana first, and I don’t know where to config the login credential
    Is it posible to connect grafana cloud or a grafana from diferent machine and DB?
    If it is posible, how?
    #14894
    In Grafana settings, enable open in frames. By default it is disabled.
    #14895
    Link example https://ibb.co/2cN8YGk
    It’s in the Views table.
