Telegram not Send Message
Forum Home Forums Communicating with Devices Telegram not Send Message
  • #14837
    lungga
    Hi, I have a problem where ModAutoControl module doesn’t send Message through Telegram driver.
    Telegram Image Log
    Before it worked, then I add some data to calculation on Channel on ID 3001 and 3002, and after that it stopped sending message.
    Does anyone know that is the problem here?
    • This topic was modified 2 years, 1 month ago by lungga.
    #14847
    In the module settings, the device 47 is specified. While in the Communicator you use the device 50. Probably, they must match.
    #14856
    lungga
    Hi, thank you for your response, my bad for not noticing the device id.
    Also, I have another question, how to back up the SCADA Database on Ubuntu Server without GUI?
    #14870
    If you use default Rapid SCADA archives, copy the archive data files for backup.
    #14875
    lungga
    I’m sorry, I meant back up the SCADA Project file, such as schematic, communication line etc.
    #14892
    Just copy the project folder. I recommend to use GitHub for storing your projects.
