Forum Home › Forums › Installation Issues › Installation of elastic report
- This topic has 9 replies, 2 voices, and was last updated 2 years, 3 months ago by
July 2, 2024 at 8:43 am #14836
fischerp
I’m trying to install elastic report and can’t get any further, although I’ve done it according to the instructions.
I am using Rapid scada 5.x and elastic report for 5.x.
elastic report is installed without errors and activated with a test licence.
According to the instructions, I have copied the sample file (ElasticReportExample.xml) into the interface folder of my project directory. I then referenced this report in the Interface table. Now a Test report entry appears in the web interface (this is the title I have given it). This entry is greyed out and cannot be selected.
Is this procedure fundamentally wrong?
Do I have to fill the sample file with meaningful information that matches my installation – real existing channels etc.)?
Thanks in advance for all tips and help
Greetings
PeterJuly 2, 2024 at 11:15 am #14844
Could you provide a screenshot of the Interface table?Do I have to fill the sample file with meaningful information that matches my installation – real existing channels etc.)?
This is not necessary for testing.
July 2, 2024 at 11:16 am #14845
MikhailModeratorAlso check ScadaWeb.log. Are there any errors after restarting the web application?
July 3, 2024 at 7:38 am #14863fischerp
ParticipantHello Mikhail,
Here you can see where the file is located and how it is integrated in the administrator.
https://ibb.co/NnYYMMb
On the computer (Win10), the files are located under c:\scada\Projects\Garwiedenweg\Interface\Elastic Report, where Garwiedenweg is the name of the project.There is something else that puzzles me, but maybe that’s because I’m working with a test license.
I install the plugin, activate it and enter the trial code. The code is accepted, with a validity of two days. After each upload (after a change) and after each restart of the web interface, the registration is lost again. I am therefore not at all sure whether I have ever tested with a valid (trial) license.I don’t know what exactly to look for in the log, I can’t find anything that is directly mentioned as an error. Here is the excerpt from the file that covers the period of my test:
2024-07-01 08:24:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-01 08:24:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 08:24:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 08:24:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 08:24:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 08:24:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 08:24:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: 4bi1mfvalz041liduz3dxbct
2024-07-01 08:24:44 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 08:24:44 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: 4bi1mfvalz041liduz3dxbct
2024-07-01 08:24:44 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 08:24:45 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
Scada.ScadaException: Unable to receive view file modification time.
bei Scada.Client.ViewCache.LoadView(Type viewType, Int32 viewID, DateTime viewAge, BaseView& view, DateTime& newViewAge)
bei Scada.Client.ViewCache.GetView(Type viewType, Int32 viewID, Boolean throwOnError)
2024-07-01 08:24:46 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:24:47 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=1 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:24:48 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=1 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:24:50 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=1 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:24:56 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=1 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 08:26:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 08:26:19 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 08:26:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 08:26:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: 4bi1mfvalz041liduz3dxbct
2024-07-01 08:26:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 08:26:24 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 08:30:56 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 08:35:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 08:35:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 08:35:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 08:35:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 08:35:59 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 08:35:59 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 08:35:59 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 08:36:28 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 08:38:41 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 08:40:10 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 08:42:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 09:02:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 09:02:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: 4bi1mfvalz041liduz3dxbct
2024-07-01 09:02:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-01 14:59:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-01 14:59:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 14:59:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 14:59:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 14:59:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 14:59:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 14:59:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 14:59:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 14:59:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 14:59:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 14:59:41 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 14:59:42 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 15:00:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 15:27:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:27:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:27:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 15:27:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:28:16 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:28:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:28:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:29:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:29:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 15:29:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:29:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:29:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:29:41 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:29:41 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:29:41 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-01 15:29:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-01 15:29:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 15:29:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 15:29:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 15:29:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 15:29:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 15:29:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 15:30:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 15:30:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:30:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:30:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:30:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:30:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:30:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:30:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:30:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:30:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:30:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:37:22 <DESKTOP-79L88KK><DefaultAppPool><ACT> Check “Dashboard” registration:
Registration key is valid. Expiration date is 02.07.2024
Computer code: =BF2CC88269372214-D2D05F9F6EBC85FE-3ED004C8E8E9329A-25CE1B6C6C78F6CD-F0BCA9B8A2FC1C75-BE00CCA6CACC6E2E-9B2E29EFA5465A4E-E5EE4F17C4D70B46=
2024-07-01 15:37:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 15:37:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 15:37:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 15:37:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:38:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:38:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:38:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:38:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:38:08 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 15:38:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:39:03 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:41:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:42:16 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:44:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:44:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:44:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:44:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:44:54 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 15:44:57 <DESKTOP-79L88KK><DefaultAppPool><ACT> Check “Chart Pro” registration:
2024-07-01 15:44:57 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:45:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:45:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:45:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 507 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:45:40 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 508 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:46:04 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240701.dat
2024-07-01 15:57:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 15:57:31 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:19:44 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:19:49 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:19:50 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:20:43 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:20:45 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:21:05 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:21:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:21:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:21:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:21:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:21:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:21:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:21:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:21:19 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:21:19 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:21:19 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:21:19 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:21:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:21:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:21:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:21:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:21:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:21:46 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:23:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:23:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:23:15 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:23:16 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:23:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:23:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:23:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:23:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:23:45 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:23:45 <DESKTOP-79L88KK><DefaultAppPool><ERR> Error loading Chart Pro plugin configuration: File C:\SCADA\ScadaWeb\config\PlgChartPro.xml not found.
2024-07-01 16:24:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:24:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:24:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:24:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:24:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:24:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:24:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:24:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:24:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:25:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:25:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:25:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:25:03 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:25:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:25:47 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:26:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:26:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:26:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:26:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:26:58 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:26:59 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:27:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:27:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:28:02 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error receiving date and time of file [Base]\incnl.dat modification from SCADA-Server: Von der Übertragungsverbindung können keine Daten gelesen werden: Eine bestehende Verbindung wurde softwaregesteuert
durch den Hostcomputer abgebrochen.
2024-07-01 16:28:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:28:02 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
Scada.ScadaException: Unable to receive the configuration database modification time.
bei Scada.Client.DataCache.RefreshBaseTables()
2024-07-01 16:28:02 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:28:02 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:28:03 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:28:07 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:28:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:28:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:28:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:28:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:28:08 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:28:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:28:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:28:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:28:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:28:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:28:39 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:28:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:29:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:29:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:30:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:30:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:31:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:31:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:31:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:31:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:32:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:33:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:33:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:33:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:33:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:33:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:33:42 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:33:42 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:33:42 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:33:42 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:33:51 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:33:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:33:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:33:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:33:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:34:06 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:34:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:34:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:34:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:34:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:34:18 <DESKTOP-79L88KK><DefaultAppPool><ERR> Error loading Chart Pro plugin configuration: File C:\SCADA\ScadaWeb\config\PlgChartPro.xml not found.
2024-07-01 16:34:52 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:35:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:36:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:37:53 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:38:54 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:39:54 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:40:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:41:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:42:56 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:43:57 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:44:31 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error receiving date and time of file [Srez]\current.dat modification from SCADA-Server: Von der Übertragungsverbindung können keine Daten gelesen werden: Eine bestehende Verbindung wurde softwaregesteuert
2024-07-01 16:44:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:44:31 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:44:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:44:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:44:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:44:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:44:36 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:44:55 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:44:57 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting daily chart data where channels=510, view ids=3:
Scada.ScadaException: User not logged on.
bei Scada.Web.UserMonitor.CheckLoggedOn(UserRights& userRights, Boolean throwOnFail)
bei Scada.Web.Plugins.ChartPro.ChartSvc.GetDailyChartData(String cnlNums, String viewIDs, Double timeOffset)
2024-07-01 16:45:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:45:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:45:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:45:00 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:45:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:45:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:45:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:45:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:45:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:45:46 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:46:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:47:01 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:47:07 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:47:27 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:47:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:47:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:47:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:47:32 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:48:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:48:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:48:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:48:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:48:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:48:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:48:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:48:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:48:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:48:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:48:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:48:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:48:21 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:48:22 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:48:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:48:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:48:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:48:37 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:49:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:49:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:50:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:50:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:50:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:50:13 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:51:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:51:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:51:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:51:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:52:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:52:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:52:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:52:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:53:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:53:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:53:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:53:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:53:57 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-01 16:54:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 510 trend from SCADA-Server. File: m240701.dat
2024-07-01 16:54:21 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error receiving file [Srez]\current.dat from SCADA-Server: Von der Übertragungsverbindung können keine Daten gelesen werden: Eine vorhandene Verbindung wurde vom Remotehost geschlossen.
2024-07-01 16:54:21 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:54:22 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:54:24 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2024-07-01 16:54:24 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-01 16:54:24 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:24 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:25 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:25 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:26 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:26 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:27 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:27 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:28 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:28 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:29 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:29 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to receive the current data file modification time.
2024-07-01 16:54:30 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-01 16:54:30 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2024-07-01 16:54:30 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=3 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 16:54:35 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-01 16:54:35 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-01 16:54:35 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-01 16:54:35 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-01 16:54:35 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-01 16:54:45 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 16:54:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-01 16:54:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 16:54:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-01 16:54:50 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-01 17:15:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-01 17:15:23 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: lgbemwm1xu0ch2aqwxwi4niy
2024-07-01 17:15:31 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-02 10:10:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-02 10:10:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-02 10:10:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-02 10:10:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-02 10:10:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-02 10:10:49 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-02 10:10:50 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:11:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:11:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:11:00 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 10:11:01 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-02 10:11:02 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-02 10:11:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 10:11:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:11:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:11:17 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 10:17:14 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:17:18 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 10:17:19 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-02 10:17:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 10:17:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:17:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:17:33 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-02 10:18:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-02 10:19:04 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 10:19:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-02 10:19:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:19:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:19:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 10:19:09 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error getting view with ID=12 from the cache or from the server: Unable to receive view file modification time.:
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Refresh the tables of the configuration database
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channels properties
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill output channels properties
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Fill input channel statuses properties
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Login without a password: admin (Administrator). IP address: 192.168.2.121
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 10:20:12 <DESKTOP-79L88KK><DefaultAppPool><ACT> Retrieve components from the installed plugins
2024-07-02 11:11:22 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-02 11:11:22 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: o3xpmjlv2z3suihm1liyi1vh
2024-07-02 11:11:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-02 22:04:25 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-02 22:04:25 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-02 22:04:25 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-02 22:04:34 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 513 trend from SCADA-Server. File: m240702.dat
2024-07-02 22:04:48 <DESKTOP-79L88KK><DefaultAppPool><ACT> Receive input channel 506 trend from SCADA-Server. File: m240702.dat
2024-07-02 22:25:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.108
2024-07-02 22:25:20 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.108. Session: 52s3i2ab1vms0j322il4e22k
2024-07-02 22:25:32 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
——————————————————————————–July 3, 2024 at 7:42 am #14864fischerp
ParticipantSomething went wrong with the screenshot of the interface table. Here is another attempt
https://ibb.co/594T050July 3, 2024 at 10:54 am #14867
MikhailModeratorSpecify the report type
@ElasticRepas shown in the manual.In version 5, use only English characters in file path.
July 3, 2024 at 2:07 pm #14872fischerp
thank you very much, now the report is where it should be and I think I understand the system. What I would still like to see is a possibility to select the values to be displayed in the frontend. Like in the “Minute Data Report”. Is this also feasible, or do I have to create a separate report for each group of values?July 4, 2024 at 7:39 am #14877fischerp
ParticipantHi Mikhail,
I now have another problem that I don’t know if it is related to the one above.
After making some changes to the Report.xml, I can no longer upload the changed configuration. Even after I copied back the original sample file and changed the entries in the interface table back to the original state, no upload is possible. Here is a screenshot.https://ibb.co/YQ4jbHX
https://ibb.co/nzbmBS3Here is also today’s log:
2024-07-04 09:16:30 <DESKTOP-79L88KK><DefaultAppPool><ACT> Request SCADA-Server state
2024-07-04 09:16:30 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-04 09:16:30 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-04 09:16:30 <DESKTOP-79L88KK><DefaultAppPool><ACT> SCADA-Server unable to open file [Itf]\ElasticReport\Testreport.xml
2024-07-04 09:16:30 <DESKTOP-79L88KK><DefaultAppPool><EXC> Application error:
Scada.ScadaException: Unable to receive elastic report configuration.
bei Scada.Web.Plugins.ElasticReport.Config.ElasticRepConfig.GetConfig(Int32 reportID, String path, Cache cache, ServerComm serverComm)
bei Scada.Web.Plugins.ElasticReport.WFrmElasticRep.Page_Load(Object sender, EventArgs e)
bei System.Web.UI.Control.OnLoad(EventArgs e)
bei System.Web.UI.Control.LoadRecursive()
bei System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Page: http://192.168.2.140/Scada/plugins/ElasticReport/ElasticRep.aspx?reportID=11
User: admin
2024-07-04 09:16:43 <DESKTOP-79L88KK><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.2.121
2024-07-04 09:16:43 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: ourdgb4gk5alvsqazvoe11jn
2024-07-04 09:16:43 <DESKTOP-79L88KK><DefaultAppPool><ACT> Application shutdown
2024-07-04 09:21:38 <DESKTOP-79L88KK><DefaultAppPool><ACT> Initialize common web application data
2024-07-04 09:21:39 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-04 09:21:41 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2024-07-04 09:21:41 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-04 09:21:41 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2024-07-04 09:21:42 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been added. IP address: 192.168.2.121. Session: ourdgb4gk5alvsqazvoe11jn
2024-07-04 09:21:43 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been updated. IP address: 192.168.2.121. Session: ourdgb4gk5alvsqazvoe11jn
2024-07-04 09:21:44 <DESKTOP-79L88KK><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.2.121. Session: ourdgb4gk5alvsqazvoe11jn
2024-07-04 09:21:49 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-04 09:21:49 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2024-07-04 09:21:49 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 192.168.2.121
2024-07-04 09:21:54 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-04 09:21:56 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2024-07-04 09:21:56 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-04 09:21:56 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2024-07-04 09:21:56 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-04 09:21:56 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 192.168.2.121
2024-07-04 09:21:58 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Incorrect username or password. IP address: 192.168.2.121
2024-07-04 09:22:05 <DESKTOP-79L88KK><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2024-07-04 09:22:08 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error connecting to SCADA-Server: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte 127.0.0.1:10000
2024-07-04 09:22:08 <DESKTOP-79L88KK><DefaultAppPool><ACT> Disconnect from SCADA-Server
2024-07-04 09:22:08 <DESKTOP-79L88KK><DefaultAppPool><EXC> Error refreshing the tables of the configuration database:
2024-07-04 09:22:08 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unable to connect to SCADA-Server. Try again.
2024-07-04 09:22:08 <DESKTOP-79L88KK><DefaultAppPool><ERR> Unsuccessful login attempt: admin – Server is unavailable. IP address: 192.168.2.121July 4, 2024 at 10:21 am #14880fischerp
ParticipantI have found another error message in the Communicator log
https://ibb.co/Gxwrrp5
maybe that helpsJuly 4, 2024 at 12:43 pm #14881
Another issue is not related to Elastic Report. Find a corresponding topic.Like in the “Minute Data Report”. Is this also feasible, or do I have to create a separate report for each group of values?
It’s supported in v6.
