First of all, you need to find out the bottle neck step by step. Please provide more details what are “locally displayed value” and “value on SCADA screen”? Screenshots will help.January 31, 2017 at 6:21 am in reply to: Raspberry Pi config: Metadata file `System.dll' could not be found #1914
MikhailModeratorAre you on Raspbian?
Yes.
You can try to install latest Mono manually as written here http://www.mono-project.com/docs/getting-started/install/linux/
I did it on Ubuntu just for testing.
MikhailModeratorCould you provide more details about the architecture of your system?
MikhailModeratorAlso you can install this utility and try to establish a connection between internal and external computers.
Does your web server located within home network or on a hosting in the Internet?
Seems you perform the right settings. What errors in log files of server and web application?January 28, 2017 at 3:25 pm in reply to: Chartpro request: Separate rows for discrete / binary inputs, etc #1906
MikhailModeratorThank you. Very interesting suggestion!
January 27, 2017 at 5:06 pm in reply to: Chartpro request: Separate rows for discrete / binary inputs, etc #1902
MikhailModeratorCould you provide a graphical example, please?
MikhailModeratorYou right. I hope it will be implemented in the future. May we can find someone as a sponsor.
MikhailModeratorThis parameter is very useful for tuning charts. If data are stored every 5 minutes, for example, you need to increase Chart gap to 300 or more to make trend continuous.
On the other hand, if you set it to 300 while data are stored every 1 minute, you can’t recognize when communication with device is unstable.
MikhailModeratorI’m mostly interesting in value of the Chart gap parameter.
MikhailModeratorYou are the first with this issue. Could you remember what settings of the Webstation app have you changed? Or post a screenshot of http://localhost/Scada/plugins/Config/WebConfig.aspx
January 27, 2017 at 6:48 am in reply to: Raspberry Pi config: Metadata file `System.dll' could not be found #1894
MikhailModeratorWhat localization do you use? I recommend to set English localization. There were issues depend on this.
January 27, 2017 at 6:46 am in reply to: Raspberry Pi config: Metadata file `System.dll' could not be found #1893
The issue is not connected with Chart Pro plugin.
System.dll is a part of .NET Framework. I think something wrong in Mono .NET Framework. Could you check the installed version of Mono by executing the command below?mono --version
January 23, 2017 at 7:49 am in reply to: webstation Scheme loading failed. Try to reload scheme #1887
Please press F12 in Chrome, go to Console tab and make a screenshot of detailed error information.I recommend to validate checkboxes of Windows components like shown in this video.
MikhailModeratorPlease provide screenshots:
1. Interface table where you define the view (Administrator application).
2. Webstation application. -
