webstation Scheme loading failed. Try to reload scheme
Forum Home › Forums › Runtime Bugs › Webstation Bugs › webstation Scheme loading failed. Try to reload scheme
  • #1884
    sguerrero18
    hello!
    Newly installed I open the web station and I get that error and after 5 seconds the web station closes and returns to login.
    http://i.imgur.com/sv7Form.png%22%20alt=%22commercial%20photography%20locations%22
    I followed all the steps of the video of your channel “Rapid SCADA. First run” and I get the same error
    Excuse my English, it’s very basic
    • This topic was modified 9 years, 10 months ago by sguerrero18. Reason: picture
    #1886
    sguerrero18
    In the previous link attach a screenshot of the error
    #1887
    Please press F12 in Chrome, go to Console tab and make a screenshot of detailed error information.
    I recommend to validate checkboxes of Windows components like shown in this video.
    #1888
    sguerrero18
    Thanks for replying, I followed your recommendations of the video, check the checkboxes of the Windows components and the problem was solved.
    Thanks again and best regards
    #2165
    svoicum
    Hello @Mikhail!
    I am facing with the same issue, but over Internet.
    My server is running on a Raspberry PI. If I connect using the local LAN IP everything works OK.
    But, if I connect from the internet (all port forwarding is OK), it loads the authentication screen, I can login just fine, but I get the same behavior as @sguerrero18.
    You can see the console here: http://imgur.com/a/2udL2
    Thanks in advance!
    • This reply was modified 9 years, 6 months ago by svoicum.
    #2168
    Try the following:
    1. Restart Raspberry Pi
    2. Do not open Webstation locally after restart, but open Webstation from the Internet.
    Does it work?
    #2169
    svoicum
    Hello!
    I was just able to try it.
    If I open Webstation from the internet it works. But now, it doesn’t work locally.
    This is a major issue, because it must be able to be viewed both from the internet and locally.
    Any possible quick fix?
    Thank you!
    #2170
    This is a known bug. It relates to the web server XSP4 that is used on Raspberry.
    Fortunately, there is a workaround. The idea – creating 2 instances of Webstation to local and remote access.
    How to:
    1. Copy the files from /opt/scada/ScadaWeb/ to /opt/scada/ScadaWebRemote/
    2. Grant access to the copied files.
    3. Register the web application:
    sudo mono-xsp4-admin add –path=/opt/scada/ScadaWebRemote –app=scadaremote
    4. In case of using SD card, protect it by moving the created folder to RAM.
    5. Open http://Host name or IP address:8084/scadaremote
