Chartpro request: independent scales
Forum Home › Forums › New Ideas › Chartpro request: independent scales
  • #1899
    dsjstc
    It’d be really nice to specify different scales for different lines.
    For example, if I need to have pressure in kPa on the same chart as boiler temperature in C, the boiler temperature will be very compressed and not visually meaningful. If each of them has a separate scale, the relationships are much easier to see.
    I’ve seen this implemented two ways, in order to isolate which scale is for which series:
    1) One scale on either side of the graph. Series labels are at the right or left to indicate which scale they use.
    2) One scale for each series, colour coded to match the series.
    #1901
    You right. I hope it will be implemented in the future. May we can find someone as a sponsor.
    #1905
    dsjstc
    roska
    Any news on that topic? I’d like to plot temperature (range 0-40°C), pH (range 6.5-7.5), redox (range 600-850) an sone binary signals on one chart. I’d buy the chart pro plugin immediately, but with all signals having the same scale this doesnt make any sense for me.
    #2316
    Nope. We are looking for a sponsor for this function ))
    You can try Dashboard plugin and place one chart below another. See the demo
