MikhailModeratorPlease provide screenshots.
MikhailModeratorYou should update ScadaInstanceConfig.xml
It was changed in the recent versions.
MikhailModeratorDB Import Plus includes additional features described in the driver docs. I haven’t tried this module by myself.
MikhailModeratorRapid SCADA 6.1.4 has been released. The changes mainly affected the web application and plugins.
Added new plugins:
– Store Plugin (included by default)
– Map Plugin: user can switch layers, plugin displays moving objects, marker labels and geometric shapes, supports custom marker icons.Thus, the work on porting modules to version 6 has been completed. The update is recommended for installation.
MikhailModeratorDo you mean DB Import Plus?
MikhailModeratorWhat was the cause of different ScadaAdmin behavior?
Please provide additional info:
1. What Rapid SCADA version do you use?
2. Press F12 in browser and check errors in the Console tab.
ExtDepMysql extension should be activated in Administrator – Tools – Options – Extensions page. If the extension is correct, it appears in the drop down list in deployment profile.
MikhailModeratorI think, if chart is open in the same page, it should be open as a popup. What do you think about chart popup?
Currently, Chart Pro supports chart views. It means that you can add a row into the views table, and open a particular chart inside common UI.
If chart is open in a new tab in full screen mode, the Close button appears.
Currently I am waiting for an publish of instruction steps on how to migrate from V5 to V6. I will definitely want to use V6.
Please read this topic. Instruction is inside the archive.
MikhailModeratorUpdate the existing Telegram Driver to read incoming messages is in the wish list. For now, I can’t provide release date.
Thank you for sharing your solution!
What is written in the device manual about sending that command?
What Modbus function is used to send that command?
If you creating a new project, I recommend to use Rapid SCADA 6, which has an auto login feature out of the box.
If you prefer to use Rapid SCADA 5, could you download the above link using VPN? -
