Viewing 15 posts - 1,501 through 1,515 (of 6,288 total)
  • in reply to: cannot get opc da value #13464
    Could you copy communication line log here?
    in reply to: cannot get opc da value #13460
    Possible reason is that Communicator works as a service while another app is a desktop application.
    You can try setting username, password and domain in the connection parameters of the OPC device.
    What is OPC DA specification version?
    What is the OPC server you try to connect?
    • This reply was modified 2 years, 8 months ago by Mikhail.
    in reply to: Chart Pro Data Timestamp Metadata #13459
    Thank you for the info.
    in reply to: Api connection #13456
    in reply to: New release Rapid SCADA 6.1.x #13455
    Rapid SCADA 6.1.4 has been released:
    – Added the Code column in the Channels table. It can be used for integration with external software.
    – OPC Classic driver supports sync mode for OPC DA.
    – Other fixes and improvements.
    in reply to: Chart Pro Data Timestamp Metadata #13454
    It’s weird.
    Anyway, today we published PlgChartPro 6.0.2.1. Please use the latest version.
    in reply to: can’t convert opc da with 5 layers to opc ua #13453
    I met this bug earlier with old OPC DA servers. I think, it is related with OPC client libraries, and we have nothing to fix in the driver. You can add OPC tags manually in the device configuration XML file.
    in reply to: Api connection #13436
    Note: you have to change ScadaWebConfig.xml, set AllowAuthApi to true.
    in reply to: Api connection #13435
    Connection is OK, but login failed. So check the log files ScadaWeb.log and ScadaServer.log
    in reply to: Chart Pro Data Timestamp Metadata #13434
    Please download and install Chart Pro again. We’ve fixed this small bug without changing the version number.
    Note: chart legend can be moved to the right if needed.
    in reply to: rapidscada v6.1 opcDA SourceCode (DrvOpcClassic.Logic) #13428
    OPC Classic Driver source code
    This code is not on GitHub, because it refers the proprietary OPC dlls.
    • This reply was modified 4 months, 3 weeks ago by Mikhail.
    in reply to: Api connection #13423
    Check TCP port that is used by the web application.
    in reply to: Multiple Levels of View Folders #13422
    1. Create similar file structure under the Views node.
    2. Specify views in the Views table.
    in reply to: Elastic Report #13421
    Is there a way to make it into minute?
    This is possible in version 6.
    in reply to: Events and Ack #13416
    Interesting idea. I suggest to try creating a module for the Server app, because it’s more flexible than formulas.
