Api connection Forum Home › Forums › Development and Integration › Api connection Tagged: api This topic has 6 replies, 2 voices, and was last updated 3 years, 1 month ago by Mikhail. Viewing 7 posts - 1 through 7 (of 7 total) Author Posts September 18, 2023 at 9:39 am #13417 quinteloskyParticipant Hi I compiled WebApiClientSample but can’t connect to rapidscada. https://ibb.co/vwy9t7w Do I need to activate something? Thanks September 19, 2023 at 11:37 am #13423 MikhailModerator Hi, Check TCP port that is used by the web application. September 22, 2023 at 8:31 am #13432 quinteloskyParticipant Hi Ok, I changed the port but I continue with problems: https://ibb.co/m4rjt9Y September 22, 2023 at 1:24 pm #13435 MikhailModerator Hi, Connection is OK, but login failed. So check the log files ScadaWeb.log and ScadaServer.log September 22, 2023 at 1:25 pm #13436 MikhailModerator Note: you have to change ScadaWebConfig.xml, set AllowAuthApi to true. September 22, 2023 at 4:23 pm #13438 quinteloskyParticipant Works !!! You are a genius Many thanks September 25, 2023 at 12:56 pm #13456 MikhailModerator 🙂 Author Posts Viewing 7 posts - 1 through 7 (of 7 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
