Elastic Report Forum Home › Forums › Understanding the Software › Elastic Report Tagged: elastic report This topic has 3 replies, 2 voices, and was last updated 3 years, 2 months ago by Mikhail. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts March 16, 2023 at 1:07 pm #12248 BangParticipant Hi, Quick question, Can I not use the same Section type in one Report format? I wanted to use 2 Time Data in one sheet but I keep getting Application Error (see Photo on link) https://mega.nz/file/0VJVGaZK#s_BtJ-sfavH3EAhb-gFjTEOb2W2C_9oAXRDCEf_O2GU The reason why I needed 2, is to separate reports in 2. Example, 1 Time Data for metering, then another for sensors. If I used only 1 Time data, I can only fit the whole PDF in an A0 Paper format. Which would be unreadable printed on A4. Please see XML on link below https://mega.nz/file/sFwFTa4A#GkNLEV7lCrlGMxmMP2MayXtPDtfiFJsjlrtsPcQvN04 (file working well if there’s only 1 TIME DATA) Thanks in advance. March 16, 2023 at 2:03 pm #12249 MikhailModerator Hi, Elastic Report supports multiple sections of the same type in a report. You should check the error details in ScadaWeb.log September 19, 2023 at 2:41 am #13420 BangParticipant Hi, Found the error on my part for this. Thanks. With regards to time detailing of elastic report, I saw options as hour, day, month ,etc. Is there a way to make it into minute? September 19, 2023 at 11:35 am #13421 MikhailModerator Hi, Is there a way to make it into minute? This is possible in version 6. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
