We’re using rapidscada to convert OPCDA to OPCUA, however, when OPCDA has 5 layers, rapidscada faild to convert DA to UA, could you please help to confirm if it support 5 layers points converter? Please give us some guidance.
I met this bug earlier with old OPC DA servers. I think, it is related with OPC client libraries, and we have nothing to fix in the driver. You can add OPC tags manually in the device configuration XML file.
