Viewing 15 posts - 1,306 through 1,320 (of 6,239 total)
  • in reply to: Whether the color of the enumeration can be modified #13835
    In Rapid SCADA 6 you can set colors for enumerations in the Formats table. See Normal-Error row for example.
    in reply to: How to use ModArcPostgreSql? #13834
    The next step is I just enable those archives with ModArcPostreSql module then Rapid SCADA will start storing data into PostgreSql database already, right?
    Yes, if default settings are used. You should select data from the database table to make sure that data exist.
    in reply to: ChartPro custom period #13833
    To select particular time period in Chart Pro, you should click and hold a left mouse button, then move the mouse to select the required period of time.
    in reply to: Modbus Data Formula #13828
    Please make a screenshot of the received data and provide an example what data you need to extract.
    in reply to: Add custom field to chanel #13826
    My vision is that the solution can include a new database schema and the custom web forms built in the Webstation application as a web plugin. It requires development that is not a part of the Rapid SCADA core.
    in reply to: Ubuntu instalation issue #13825
    We update keys from v5 to v6 on the same machine for free.
    Common license terms are also work, please check this link.
    in reply to: Add custom field to chanel #13819
    The Channels table has the particular number fields. To add new properties related to channels, I suppose, an additional database table should be added to implement customer needs.
    For example, you create a database schema using PostgreSQL, and develop web UI to edit it. Your data would refer Rapid SCADA channels.
    in reply to: Login Page #13818
    Try pressing Shift + F5 or Ctrl + F5 in browser to refresh.
    in reply to: How to use ModArcPostgreSql? #13817
    Open the Schemas node and check what schemas are available. You should find data there.
    in reply to: Don’t display some events #13816
    Thank you for the info.
    in reply to: New release Rapid SCADA 6.1.x #13811
    Rapid SCADA 6.1.6 update has been released.
    – Added a new CSV reader driver that retrieves data from CSV files.
    – Fixed errors.
    in reply to: Login Page #13810
    Images are located in SCADA\ScadaWeb\wwwroot\images
    You can overwrite them.
    in reply to: Internal server error (500) #13806
    Open the Administrator application and check log files of the web application for additional details.
    in reply to: Communicator Send only modified data of device tags setting #13805
    Then you can enable PostgreSQL archives. For more details please create a new topic. This topic is about Communicator.
    in reply to: Update historical data in V6 #13795
    I plan to make and share a new converter for converting history data between.dat and.csv.
    It would be great. It could be added to https://github.com/RapidScada/scada-community repository.
    • This reply was modified 2 years, 4 months ago by Mikhail.
